![]() | Home > My Range Rover > Cold Turkey over, think I've found my next one! |
Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 57 ![]() ![]() ![]() |
Sent a pm |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 197 ![]() ![]() ![]() |
Sorted👍 I’m just a bit thick on electrical connectors for some reason!!?? A couple of observations while I’ve been doing the oil cooler swap Three of the bolts that hold the oil cooler assembly down were soake in oil so that gasket was beginning to leak But it’s clear now, the main culprit was the rear o rings on the oil pipe |
Steve200TDi Member Since: 08 May 2019 Location: Sussex Posts: 3 ![]() ![]() |
Thank you for the excellent how to guide!
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Unnecessary quote removed
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 83 ![]() ![]() |
Does anyone know of a good supplier for the part that is bound to break when I do this job the intercooler pipe with the coolent feed pipes? See attached pic.
It won't break unless you are very ham fisted with removing it. Main issue is the seal to the TB which can be improved using large O rings. 2012 TDV8 Vogue (L322) |
Well, managed to do the whole oil cooler swap and no matter how gentel I was still managed to snap the connector trying to remove the pipe which had gone rock solid on it, now waiting for new part tomorrow to hopefully finish the job!!!
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
Hi all
Once you have gone to the effort of removing the plenum donut etc to get at it then you may as well replace the whole lot for peace of mind. The filter and cooler at one single item BTW. 2012 TDV8 Vogue (L322) |
Hi Jaydee
Mfcetin Member Since: 26 Jun 2023 Location: NĂĽrnberg Posts: 69 ![]() ![]() ![]() |
I just started with taking out the plenum but I got stuck already at the beginning.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
If you’ve not tried already get some penetrating oil on and leave for a couple of hours. Here’s what I have used in the past:
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Is that the plate across the front that the intake sits on? I couldn’t |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 56 ![]() ![]() ![]() |
If you have stud extractors, these work well on these in an impact wrench to pull them out. |
