![]() | Home > Technical (L405) > Passenger door wont unlock |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 245 ![]() ![]() ![]() |
I found a used one (LR078743) in Canada for $150 CAD. |
The used door latch I found on EBay worked. Replacement took about an hour with a friend. Another set of hands was helpful. Thanks for the help! As a side note, we spent the other two hours replacing the front differential, rear differential, and transfer case fluids. 🥰 Only the transmission fluid left to do. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
One of my rear doors refuses to unlock from either the inside or outside. I can see from this thread what the problem might be, what I can't do however is open the door in order to remove the trim and access potentially faulty components. Anyone know how to get round this?
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
I recently had an issue with the child locking system following a battery re-charge while it was at MD - an ecu reset sorted it out - maybe worth a try? Good luck |
Stuart4347 Member Since: 04 Dec 2022 Location: St neots Posts: 1 ![]() ![]() ![]() |
My 2013 L405 front passenger door wont unlock. The lock light is on, on the door! The door will not unlock if you try to unlock using the hande inside the car.
Jag66 Member Since: 04 Nov 2023 Location: West Sussex Posts: 5 ![]() ![]() ![]() |
Resurrecting this thread as I have just experienced the same , the passenger door refuses to open.
