Home > Technical (L405) > Passenger door wont unlock
Whistle Whistle Whistle Good luck with that sir Thumbs Up
Post #620520 18th Jan 2022 11:46pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I found a used one (LR078743) in Canada for $150 CAD. Very Happy Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #620826 21st Jan 2022 6:06pm
pld118
Cam-Tech-Craig wrote:
Did they definitely change yours…? Or did they lube it first?
On closer inspection of my service and maintenance records Craig, there is no reference that they completed the work they said they would/ had; and on asking the garage to check their records they say they’ve no record of the repair actually having been done. Anyhoo, it’s booked in for a service in a couple of weeks and they will get a second chance to fix it Thumbs Up
Post #621381 25th Jan 2022 7:03pm
Bora20
The used door latch I found on EBay worked. Replacement took about an hour with a friend. Another set of hands was helpful. Thanks for the help!
As a side note, we spent the other two hours replacing the front differential, rear differential, and transfer case fluids. 🥰 Only the transmission fluid left to do. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #621809 29th Jan 2022 6:35pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
Hoe do I get the door open?
One of my rear doors refuses to unlock from either the inside or outside. I can see from this thread what the problem might be, what I can't do however is open the door in order to remove the trim and access potentially faulty components. Anyone know how to get round this?
Thanks.
Post #641622 1st Sep 2022 8:41am
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
I recently had an issue with the child locking system following a battery re-charge while it was at MD - an ecu reset sorted it out - maybe worth a try? Good luck Thumbs Up
Post #641806 2nd Sep 2022 4:48pm
Stuart4347
United Kingdom 2013 Range Rover Autobiography SDV8 Siberian Silver
My 2013 L405 front passenger door wont unlock. The lock light is on, on the door! The door will not unlock if you try to unlock using the hande inside the car.
However if I use the auto unlock with the key in my position it will unlock.
Thoughts!!!!
Thanks,
Stuart
Post #649836 4th Dec 2022 5:26pm
Jag66
England 2014 Range Rover Autobiography TDV6 Fuji White
Resurrecting this thread as I have just experienced the same , the passenger door refuses to open.
No signs prior to this that the lock was playing up , thinking about this now I heard the central locking engage as I was driving along but at the time had the grandchildren in the back making a din , heard the click but didn’t really give it any thought until the fragrant one couldn’t exit the car , finally managed to extract her via the drivers side , but it absolutely won’t budge , I’m not beyond taking a look at the latch mech myself but cannot for the life of me find anything about opening the door without total destruction , it would make more sense to me if the lock had failed whilst cycling it but not whilst driving along , the wife was not guilty of inadvertently pressing the locking on the door as her left arm is in plaster currently any help would be greatly appreciated
Paul
Post #712581 23rd Feb 2025 11:31am
