Home > Technical (L322) > Egr delete...
Page 3 of 7 <1234567>
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
The kit is straight forward enough to replace
2 bolts 13mm removes the pollen filter
Remove engine cover
Unplug the 2 egr connectors
Move silver pipes across top of engine and tie back 3 8mm bolts
Move engine cover bracket back 4 10mm bolts
You will have to move some wiring looms across but don’t have to disconnect them
Then you can see what your doing 4 torx bolts each side will remove the egr angle pipes
Now blank out with 4 new bolts each side provided as depth of bolt is slightly smaller
Then reassemble
Max 1 hour
Egr valves will work as normal thus not illuminating light but are completely mechanical disabled
If they did fail worst case(they will not cause damage as they are not in system just turn on eml) —just pay to get them mapped out
Post #489477 21st Sep 2018 4:36pm
bishbosh10
Isn't an egr delete an MOT fail nowadays? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #489481 21st Sep 2018 5:52pm
Benner91
It is not an mot failure I reaserched this before
Thanks
Post #489498 21st Sep 2018 7:41pm
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Not an mot failure, mine has egrs deleted, had it tested yesterday...passed with no issues Thumbs Up
Post #489499 21st Sep 2018 7:46pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I'm pretty sure it is an MOT fail. They're unlikely to spot it as they won't take the engine cover off, but if they're aware, I'm confident it's a fail
Post #489500 21st Sep 2018 7:48pm
rar110
Well done.
It sounds like your EGRs might have been stuck open if the motor is now generally smoother. So doing this was probably a very fortuitous move. ______________________________
Post #489515 21st Sep 2018 9:40pm
BigJon
Australia 2007 Range Rover Vogue TDV8 Chawton White
I have been running emulators for over a year now. About a month ago I had an EGR cooler failure, pushing coolant straight out the exhaust system. Spectacular clouds of coolant steam that would have done James Bond proud. I now have no EGRs or coolers at all. I suspect I need to refit the thermostats from the coolers into the hose joiners I made as it runs a bit cooler than it used to. Other than that, no issues.
Post #489522 22nd Sep 2018 1:42am
rar110
Good one Jon.
I suppose if the EGRs were operating the coolant may have made its way into the motor? ______________________________
Post #489523 22nd Sep 2018 3:32am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
My tips for fitting the kit in case they're any use to anyone
. Make sure you have a long reach pick up tool such as a magnetic type or 'grabber'
. You need a T30 bit which is secure in its holder. Mine wasn't and I nearly lost it. So make sure you have a longish (6"?) reach T30 tool that won't come apart and get lost in the depths of the engine
. I found it easier to disconnect the plugs even though you don't have to. It was then easier to access the securing lugs and disconnect them from the support bracket
It was a job I wasn't looking forward to but in reality it wasn't too bad. Just be extremely careful not to drop anything... 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #489533 22nd Sep 2018 9:14am
BigJon
rar110 wrote:
Good one Jon.
I would think so.
Post #495193 11th Nov 2018 2:56am
rar110
I might have to get my EGRs removed. ______________________________
Post #495194 11th Nov 2018 3:34am
BigJon
I was told it is a very uncommon failure for the coolers to split. Guess I am just lucky!
Post #495195 11th Nov 2018 3:44am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Well after reading these posts I have ordered the blanking kit and weather dependent I will fit on Wednesday or Thursday and take photos hopefully
Never liked egrs so anything that takes them out the loop has to be a good thing for me
Post #495284 12th Nov 2018 10:37am
gj88
Which one did you go for Henda? Thinking about doing the same next weekend
Post #495287 12th Nov 2018 10:51am
Henda
The same ones as posted on this thread £34.89 posted
It's got to be worth a try as all the posts on here about egrs failing and destroying the turbos to me means new turbos and egrs equals £££££'s or a few quid and maybe an eml light on before a delete maybe
I'll take plenty photos
Post #495302 12th Nov 2018 11:31am
