Home > Technical (L322) > rear diff issue |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
today we got the bong for , transmission component slipping, after a reset its straight back again
31st May 2018 6:20pm |
Thanks for going to that effort
31st May 2018 8:49pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
Can i just ask how many miles you have on it |
1st Jun 2018 1:29pm |
sure just coming up to 83000 |
1st Jun 2018 3:42pm |
I would try the oil change 1st just got to 73000 on mine all going well in that area . just sitting a bit wonky of late but seems to have sorted its self out for now ............................ |
1st Jun 2018 10:58pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Has your car got the electronic diff lock?If it has can be that the difflock needs a cleanout. 2012 TDV8 Vogue SE 4.4 |
2nd Jun 2018 8:26pm |
Yes it has the ediff
2nd Jun 2018 9:55pm |
No not oil change!
3rd Jun 2018 7:10pm |
Ok thanks
3rd Jun 2018 7:49pm |
4th Jun 2018 8:09pm |
well I have changed the rear diff oil (quite emusified) and transfer box oil (very clean) and now need a 14mm allen key to do the front diff
18th Jun 2018 12:04pm |
After unplugging and plugging back in the connector to the motor on the rear diff and giving the housing a few taps with a hammer , the situation remains , open circuit to motor brake , so without a pit or lift it looks impossible to sort out as it looks too tight to get the assembly out , a job for another time me thinks or it could just end up being an open diff for a while yet |
20th Jun 2018 2:25pm |
Got to say after the gearbox oil has been changed and new filter and plastic pan fitted theres a definite improvement to the slickness of changes up and down the box.
10th Jul 2018 5:32pm |
I had this problem last year and it was the actuator motor failure, do you gat a cascade of failures coming up on you IID tool?
16th Jul 2018 5:00am |
