![]() | Home > Technical (L322) > rear diff issue |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
today we got the bong for , transmission component slipping, after a reset its straight back again
Thanks for going to that effort
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Can i just ask how many miles you have on it |
sure just coming up to 83000 |
I would try the oil change 1st |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Has your car got the electronic diff lock?If it has can be that the difflock needs a cleanout. 2012 TDV8 Vogue SE 4.4 |
Yes it has the ediff
No not oil change!
Ok thanks
well I have changed the rear diff oil (quite emusified) and transfer box oil (very clean) and now need a 14mm allen key to do the front diff
After unplugging and plugging back in the connector to the motor on the rear diff and giving the housing a few taps with a hammer , the situation remains , open circuit to motor brake , so without a pit or lift it looks impossible to sort out as it looks too tight to get the assembly out , a job for another time me thinks or it could just end up being an open diff for a while yet |
Got to say after the gearbox oil has been changed and new filter and plastic pan fitted theres a definite improvement to the slickness of changes up and down the box.
I had this problem last year and it was the actuator motor failure, do you gat a cascade of failures coming up on you IID tool?
