Home > Technical (L322) > rear diff issue
dingg1
rear diff issue
today we got the bong for , transmission component slipping, after a reset its straight back again
P0894 rear diff
anyone have any idea what the issue may be ?
iid tool live values
are:-
actual locking torque ON
clutch over temp events 0
clutch temp 22
motor over temp events 0
motor temp 27
percent travel left on clutch 70
diff control override status NORMAL
motor brake request status INACTIVE
motor brake status INACTIVE
open diff override status ACTIVE
sump temp 24
slip speed 0
sump overtemp event count 0
torque limit 2.5kN
torque setpoint ON
anyone have any idea what the issue may be from that info?
thanks
ps I'm hoping it just needs an oil change Confused
eta car was stationary when reading were taken
Post #479821 31st May 2018 6:20pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I'll see if I can get the info out of mine for comparison.
[Edit: Just checked - pretty much the same as yours, even down to the clutch life left at 70%! My torque limit is given in lb/f at 1874 which converts to 2.54kN - pretty much the same.
As far as I can tell there isn't anything wrong with your data there.]
Post #479832 31st May 2018 8:17pm
dingg1
Thanks for going to that effort
If no one else has any input , I reckon an oil change is in order to see if that sorts it out
Wonder if ctc has seen this before?
Any input welcome
Thanks again
Post #479840 31st May 2018 8:49pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Can i just ask how many miles you have on it
Post #479877 1st Jun 2018 1:29pm
dingg1
sure just coming up to 83000
Post #479897 1st Jun 2018 3:42pm
MR GLOVER
I would try the oil change 1st Thumbs Up just got to 73000 on mine all going well in that area . just sitting a bit wonky of late but seems to have sorted its self out for now ............................ Laughing
Post #479916 1st Jun 2018 10:58pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Has your car got the electronic diff lock?If it has can be that the difflock needs a cleanout. 2012 TDV8 Vogue SE 4.4
Post #479965 2nd Jun 2018 8:26pm
dingg1
Yes it has the ediff
Can you explain further re clean out
Guess you mean oil change?
Post #479975 2nd Jun 2018 9:55pm
Frans@Yamorna
No not oil change!
The e-actuator that sits on top of the diff can get contaminated with mud or water.It must be removed(not a nice job on a D3) and cleaned out.No rocket science just difficult to get to.All D3/4,Sport and FFRR here in RSA has them standard and your problem sounds familiar!!The slip is in the actuator. 2012 TDV8 Vogue SE 4.4
Post #480029 3rd Jun 2018 7:10pm
dingg1
Ok thanks
I'll have good poke about once the fluids arrive
Going to do tx box, both diffs and get it booked in for gbox oil service at zf specialist
Post #480033 3rd Jun 2018 7:49pm
Frans@Yamorna
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #480144 4th Jun 2018 8:09pm
dingg1
well I have changed the rear diff oil (quite emusified) and transfer box oil (very clean) and now need a 14mm allen key to do the front diff
the slipping component code p0894 has not came back up
BUT I now have P186 A 00
which is diff lock up actuator brake open circuit , so looks like I need to get under again and check any connections I may have disturbed
(once my back sorts itself out I'm getting too old for scrabbling about underneath cars Rolling Eyes )
Post #481260 18th Jun 2018 12:04pm
dingg1
After unplugging and plugging back in the connector to the motor on the rear diff and giving the housing a few taps with a hammer , the situation remains , open circuit to motor brake , so without a pit or lift it looks impossible to sort out as it looks too tight to get the assembly out , a job for another time me thinks or it could just end up being an open diff for a while yet Rolling Eyes
Post #481456 20th Jun 2018 2:25pm
dingg1
Got to say after the gearbox oil has been changed and new filter and plastic pan fitted theres a definite improvement to the slickness of changes up and down the box.
Suspect its the first time its been done at 84k
Post #483118 10th Jul 2018 5:32pm
I had this problem last year and it was the actuator motor failure, do you gat a cascade of failures coming up on you IID tool?
Stuff like Terrain Response failure and traction control failure from the missing signal from the rear diff. 2008 MY Supercharged
Post #483545 16th Jul 2018 5:00am
