Home > Technical (L322) > TDV8 2012 Westminster clicking noise near to radiator
Page 2 of 3 <123>
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Does anyone’s 4.4 TDV8 do this when warm?
My Weston is fine when cold but develops a ticking noise when warmed up. It appears to come from the drivers side area of the engine, but it’s hard to pinpoint. More toward the back perhaps. It’s not the FBH, it’s not needed here.
It’s not the AC, that’s recently been done.
I’ve done 10k so far and it’s not changed, no worse no better. No smoke, no warning lights.
I wondered it it was due to oil warming up and revealing a worn valve or something? Apart from that the engine is fine, no other issues or fault codes.
But it’s so damn annoying. If I can, I’ll post a vid at some point- thanks. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #530155 6th Oct 2019 9:58am
Fox889
Yep, mine does it as well.
Seems to go after a few seconds, I thought it could be to with height vales, valve hub for suspension?
Doesn't seem to get any worse so I wasn't particularly bothered. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #530157 6th Oct 2019 11:29am
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
I have this noise when my vehicle is in position height of access...
Post #530219 7th Oct 2019 7:28am
TDV8_Tommy
Thank, mine does it all the time once warmed up irrespective of suspension height. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #530264 7th Oct 2019 7:14pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Listen to the throttle body. They strip their nylon gear and then click. Answer is to replace. A real DIY job. Part is not overly expensive. RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #538261 22nd Dec 2019 9:54pm
TDV8_Tommy
Thanks, Sarchopperman - I dug out your post relating to this.
To me though, the symptoms do not match mine. This only happens when the car is running, is warmed up and is engine speed dependent.
To my knowledge, the EGR has no parts that would produce a constant 'tick tick tick' I think it's about 2 ticks per second. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #538283 23rd Dec 2019 11:10am
accessorie belt tensioner? ... - .- -.
Post #538285 23rd Dec 2019 11:36am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
check engine oil level. Cheers
James
Post #538402 24th Dec 2019 1:33pm
TDV8_Tommy
Oil is checked more than once a week.
I'll get the tensioner looked at, thanks, Stan. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #538404 24th Dec 2019 1:53pm
Corsica
Good to know to know the solution
Post #538417 24th Dec 2019 3:59pm
JST
Ok, not that then
My 4.4 ticked when engine oil was low. Cheers
James
Post #538581 27th Dec 2019 9:50am
TDV8_Tommy
Hi all,
I’ve attempted to demonstrate the ticking noise I’ve got. The link below is the cold engine at idle - no ticking.
The next link below is with the engine up to temperature after a drive, clearly audible is the ticking noise from the drivers side - back from the front and more like lower down under the car near the drivers wing? So weird.
Excuse the quality - first stab at YouTube!
Any suggestions welcome - thanks 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #538812 29th Dec 2019 2:16pm
nino_nino
when was the last time you changed transfer box oil? i get similar noise from TB that goes away when oil in the transfer case is changed. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #538837 29th Dec 2019 6:46pm
TDV8_Tommy
Thanks nino, if I recall they were done by the last owner at approx 80k, the car has done 99k now. It’s an easy and cheap fix.
Now to determine what oil to get...! 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #538859 29th Dec 2019 10:19pm
nino_nino
I use this-RAVENOL DTF-1 Transfer Fluid TF-0870
https://www.ravenol-direct.uk/ravenol-transfer-fluid-tf-0870.html
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #538882 30th Dec 2019 8:21am
Page 2 of 3 <123>
