![]() | Home > Technical (L322) > TDV8 2012 Westminster clicking noise near to radiator |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Yep, mine does it as well.
Corsica Member Since: 03 Jan 2019 Location: Corse Posts: 50 ![]() ![]() ![]() |
I have this noise when my vehicle is in position height of access... |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
Thank, mine does it all the time once warmed up irrespective of suspension height. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
Listen to the throttle body. They strip their nylon gear and then click. Answer is to replace. A real DIY job. Part is not overly expensive. RR L322 TDV8 4.4 SE 2019 to present
Thanks, Sarchopperman - I dug out your post relating to this.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
accessorie belt tensioner? ... - .- -.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
check engine oil level. Cheers
Oil is checked more than once a week.
Good to know to know the solution |
Ok, not that then My 4.4 ticked when engine oil was low. Cheers James |
Hi all,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
when was the last time you changed transfer box oil? i get similar noise from TB that goes away when oil in the transfer case is changed. 2012 TDV8 Black Edition
Thanks nino, if I recall they were done by the last owner at approx 80k, the car has done 99k now. It’s an easy and cheap fix.
I use this-RAVENOL DTF-1 Transfer Fluid TF-0870
