Home > Technical (L322) > TDV8 2012 Westminster clicking noise near to radiator |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Yep, mine does it as well.
6th Oct 2019 10:29am |
Corsica Member Since: 03 Jan 2019 Location: Corse Posts: 50 |
I have this noise when my vehicle is in position height of access... |
7th Oct 2019 6:28am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 398 |
Thank, mine does it all the time once warmed up irrespective of suspension height. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
7th Oct 2019 6:14pm |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 |
Listen to the throttle body. They strip their nylon gear and then click. Answer is to replace. A real DIY job. Part is not overly expensive. RR L322 TDV8 4.4 SE 2019 to present
22nd Dec 2019 8:54pm |
Thanks, Sarchopperman - I dug out your post relating to this.
23rd Dec 2019 10:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35366 |
accessorie belt tensioner? ... - .- -.
23rd Dec 2019 10:36am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
check engine oil level. Cheers
24th Dec 2019 12:33pm |
Oil is checked more than once a week.
24th Dec 2019 12:53pm |
Good to know to know the solution |
24th Dec 2019 2:59pm |
Ok, not that then My 4.4 ticked when engine oil was low. Cheers James |
27th Dec 2019 8:50am |
Hi all,
29th Dec 2019 1:16pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
when was the last time you changed transfer box oil? i get similar noise from TB that goes away when oil in the transfer case is changed. 2012 TDV8 Black Edition
29th Dec 2019 5:46pm |
Thanks nino, if I recall they were done by the last owner at approx 80k, the car has done 99k now. It’s an easy and cheap fix.
29th Dec 2019 9:19pm |
I use this-RAVENOL DTF-1 Transfer Fluid TF-0870
30th Dec 2019 7:21am |
