![]() | Home > Technical (L322) > Resistors to slow flash on LED 2010 lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
sounds like you might have the wrong resistors wired in nick, are they 25 watt ones? ... - .- -.
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Think they are 50 if i remember correctly. Came as a kit. I even tried wiring the front ind bulbs back in line and these just flashed twice as quickly as well as the led ones. Not tackled back kit yet.
if you have a resistor on each indicator , i just wonder if one is faulty and causes the double flash. ... - .- -.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
When i've fitted resistors, they have been wired in line with the +ive. Not across the -ive & +ive. Ian |
the resistors have to be wired in parallel as if its another bulb ..this is supposed to 'fool' the ecu into thinking there is a normal bulb there... ... - .- -.
That makes more sense to me, but the wiring diagram supplied definatly says to go across the 2 and iv'e googled fitting resistors and the posts that came up suggest wiring accross the two aswell? |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Yep series not parallel.
i've put two resisters on my fogs [which i aint got now , dont ask |
nick, seems that series might work , why, i dont know , maybe worth a try mate. ... - .- -.
So, you reckon wiring in 'series' ( in line, in the positive) may work??
Its all done with smoke and mirrors. Nothing to be lost in giving it a try. Putting the resistors in the way you have will actually drop the voltage across the bulb as some of the voltage will go to earth via the resistor creating heat.
I think i got a bit lost then in the smoke and the mirrors |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
It has to be parallel Porsche Cayenne
