Home > Technical (L322) > Resistors to slow flash on LED 2010 lights |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Hi yes you have to do both front and rear the wattage is not the issue its the resistance wattage is about the heat dissipation resistance is about fooling the lcm to think it has a incandesant lamp connected Porsche Cayenne
26th Jan 2011 7:27pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
nowt to do with voltage, its amps that the resisters pretend to be ..the ecu sends a voltage to the bulb and if it doesn't get the correct resistance back it puts up an error, hence the need for resisters if you have leds .....now it could be that the RR setup is different and somehow picks up on the positive only feed so putting a resister in series 'might' give the ecu the reading it needs..
26th Jan 2011 7:28pm |
correct hense my reply resistance is the key !!!! Porsche Cayenne
26th Jan 2011 7:34pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
oodathort- you cant remember what colour wires the rear indicator live/ground were can you??
26th Jan 2011 8:30pm |
Hi ground is brown
27th Jan 2011 6:59am |
Thanks. I have decided to get someone with some elec knowledge to sort it out (as i prob should of done in first place) so will update with results once done. Thanks for input/ comments. |
27th Jan 2011 9:22pm |
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 |
They need wiring in parallel and you must do all four corners. If your anywhere near yorkshire i will be happy to sort it for you for a few beer tokens! Heres my 03 working.
28th Jan 2011 8:26am |
Ogy, you've no idea how much i'd like to take you up on that offer but i think your 300 odd miles away!!
28th Jan 2011 2:57pm |
nick, i thought you had done all four and had the problem..if you've only done the front two then when you do the rears it should be ok.. ... - .- -.
28th Jan 2011 3:18pm |
No, only front as thought they would work independantly. Will have to wait till next week now but will update with results. |
28th Jan 2011 8:20pm |
....that might be the problem solved [hopefully ] ... - .- -.
28th Jan 2011 8:22pm |
While your there scarey and clearly a man of knowledge I've seen a blanket repair service for £150 for mk4 sat nav units. If i bought this
28th Jan 2011 8:25pm |
looks like the one nick, makes sense what you propose ....i'll see if i can find some info here..
28th Jan 2011 8:32pm |
From what i've read looks like straight swop and seem to go for £350+ so if it stays around this and use this
28th Jan 2011 8:37pm |
