Home > Technical (L405) > Idle speed and Vibration
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
My SDV8 seems very vibey at idle, whether in neutral or held in drive. I can feel a vibration through the steering wheel, pedals and centre console.
Is this normal?
Also, what's the normal idle revs for this engine? Mine is roughly 630 rpm 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #459537 4th Dec 2017 12:22pm
Paul thornton
Idle speed seems a bit low to me.
I'm no expert that particular engine but I'm sure it should be around 200rpm higher.
If so, then that will be the cause of your vibration.
Post #459539 4th Dec 2017 12:42pm
Baltic Blue
Buz,
I have the same engine, but in a 322,: ticks over at 750rpm with absolutely no vibration, if that helps any.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #459543 4th Dec 2017 1:01pm
Vogue
Idle speed is too low - vibration won't be doing the engine any good either.
Would say around 700/750 is where you want to be. We had the same in a big 6 Cykinder Tractor - 50 rpm up made a massive difference / plus keeps the oil pressure up and alternator charging 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #459547 4th Dec 2017 1:29pm
GlassMan44
United Kingdom 2014 Range Rover Autobiography SDV8 Mariana Black
I have a resonance / vibration at idle also, as soon as I increase revs it disappears but returns at idle it’s been back to dealers,three times but still there any ideas would really help it’s driving me mad
Post #465203 20th Jan 2018 4:08am
nino_nino
My idles at 680 rpm, steady and no vibracion. I do use 1/2 L of 2T oil every fourth tank of fuel. I think you would be pleasantly surprised by the difference a bit of 2T oil makes. Smile
Post #465215 20th Jan 2018 9:23am
Vogue
Blimey is your Diesel so poor quality you need to add oil to it? I'd be very careful adding oil to a modern Diesel in case it ruins the DPF or any of the other emmission systems and results in fault codes/ the engine management light coming on, reduced performances and significant repair costs.
Case in point being another Land Rover in the family - don't ask! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #465220 20th Jan 2018 11:02am
