![]() | Home > Technical (L405) > Idle speed and Vibration |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Idle speed seems a bit low to me.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
Buz,
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3780 ![]() ![]() |
Idle speed is too low - vibration won't be doing the engine any good either.
GlassMan44 Member Since: 21 Nov 2017 Location: London Posts: 7 ![]() ![]() ![]() |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
My idles at 680 rpm, steady and no vibracion. I do use 1/2 L of 2T oil every fourth tank of fuel. I think you would be pleasantly surprised by the difference a bit of 2T oil makes. |
Blimey is your Diesel so poor quality you need to add oil to it? I'd be very careful adding oil to a modern Diesel in case it ruins the DPF or any of the other emmission systems and results in fault codes/ the engine management light coming on, reduced performances and significant repair costs.
