![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
We have only had one report of a 2010/2012 heated/cooled driver seat failure.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Maybe start with the basics:
MarkA Member Since: 15 Feb 2017 Location: West Yorkshire Posts: 35 ![]() ![]() ![]() |
Will follow with interest as my drivers seat also doesn't heat, just assumed my fat arse was too heavy.
Tell everyone how many miles you have now sat in it !!! Mark.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
round filter is washable, i did my on both sides. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
Filter? 2011 Range Rover Vogue SE 4.4 TDV8
it is twist and release. . |
It's at 220,000 but sat in airport parking having a rest for a couple of weeks. |
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 ![]() ![]() |
Thanks chaps - I'll give the filter a clean this evening - hope it's that! |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Tinribs
For a bit of nerd speak about Peltier cells
Wow , technology 👍👍👍
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 ![]() ![]() ![]() |
mine failed also, I removed it and found one of the solder joints failed on 12v feed from moisture it looks, just retouched with iron. It is called a module but simply is a fan and peltier coil, not really worth the $500, think was made by Lear. |
Thanks for your advice Zeppfish |
