![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
I guess the Aliexpress link is specific to individuals as it works for me fine. Unfortunately their share options are limited to platforms I don't use I will look deeper but I think I just did a search for car seat cooler and the items were amongst the usual irrelevant junk the Aliexpress always spams you with. 2011c Vogue SE 4.4 Oil Burner
OK, try searching for TZ032461 or for car seat refrigeration peltier in Aliexpress. If you select one you will find it then provides links to even more.The best I found for delivered price was £25 and pence although I think VAT needs to be added at final checkout. 2011c Vogue SE 4.4 Oil Burner
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 562 ![]() ![]() ![]() |
Hi, has anyone tried one of these Aliexpress units for real ?
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 63 ![]() ![]() ![]() |
Yes I just replaced mine with one of these last week and works fine so far 🙂
Thanks for that. The guy who was repairing mine can't get the parts now so it's fallen through.
Griffiths Member Since: 03 Feb 2024 Location: shropshire Posts: 2 ![]() ![]() ![]() |
Hi Tinfish,
Hi, Peltier part just arraived, but the rest of the unit is still with the other "fixer", soon as I get that back I'll replace the peltier and hopefully all good.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1214 ![]() ![]() ![]() |
Just bit the bullet and bought the whole unit HHK500060.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 ![]() ![]() ![]() |
I ordered one of the alieexpress peltiers, took a couple of weeks to arrive and was about £32 all in, it seems to work , we'll just have to wait and see how long now , hopefully the OH will be happy as I only ever use the cooling but she likes the heater . |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
Was your ducting split and did you manage to fix? I have ordered a pettier too |
Ducting was fine and still soft and pliable , had car nearly 8 years now and only just got round to sorting seat heater (not a priority for me ), i'd had it apart a few years ago to check ducting when info was less readily available and peltiers were unavailable , thought for £30 rather than a few hundred it was worth a punt , just got to see how long it lasts for now , time will tell , back heats up a lot more than base so base one could probably do with changing too but i think they are a tad more awkward to get out . |
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 ![]() ![]() ![]() |
just a quick update on this, AliExpress Peltier unit fitted - fairly easy swap out. Cost around £32 and works a treat!
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 73 ![]() ![]() ![]() |
Just stripped my drivers seat down & confirmed that the peltier is not working with only about 3 ohms of resistance. I too will get one ordered this week. I just have a small crack at the base of the ducting so will fix it with a little baking soda & super glue and the job will be a gooden.... 2010 RR Autobiography 5.0 SC
Update on my fix: Less than a year later the Peltier element from Aliexpress broke down. I had ordered two of them so I put in the new one and lets see how long this one will last. Anyone knows if the Peltier element from Ukraine is any better than Chinese one? I read that it is from a company called Klifex in Kiev but I am not sure if it was really manufactured in Ukraine or they are just resellers of the chinese ones ![]() |
