Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 23 of 26 <123 ... 2223 242526>
MarianaWestminster
JNC, whata the lead time on these?
And can you tell me the regular price vs the discounted group buy price?
Kind regards
Post #654660 25th Jan 2023 9:27am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
We usually sell the kits for £140 (this is due to increase shortly).
The group buy price will be £120 but we will offer to install the components free of charge if you send us your faulty unit.
Lead time after order approx 7-10 days.
Post #654661 25th Jan 2023 9:53am
KristoffL322
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I have this problem with my L322 Westminster, both driver and passenger side. I have just bought the GAP IID tool so I can check seat temps with the live data function and determine if it’s just the back or the base units too, hopefully.
I'm not 100% sure about diagnostic process to follow, but I will read through this whole thread and try and work out the steps to make sure I know for sure what my faulty components are.
I would then like to send them to you for repair JNC.
Post #654673 25th Jan 2023 11:57am
MarianaWestminster
Hi JNC,
Thanks for the prices.
Happy to solder in the new peltier myself.
How much am I looking at for just the peltier unit, delivered, outside of any group buys?
Kind regards
Post #654684 25th Jan 2023 2:27pm
icarus76
Hi,
Just to let you know I ordered the Peltier cell on its own from EBay for about £80 a couple of weeks ago and it arrived on Friday all the way from the Ukraine.
Pretty impressed with delivery time given the circumstances Smile
Post #655667 5th Feb 2023 10:50am
Justin_Sherfy
United States 2012 Range Rover HSE 5.0 V8 Baltic Blue
I wanted everyone to know I ordered a peltier cell from Ebay too. My passenger side seat heater was throwing the Fault code(s): B1231-7A and B122F-98.
It took about a month to receive the part. I replaced the peltier cell in the seat heater, and it works.
I enjoy my L322 and like to keep everything working. This forum helps me a lot. Thank you! 2012 HSE 5.0 V8
Post #659169 12th Mar 2023 6:16am
Yellopin
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
I too can confirm that the eBay one from Ukraine works and is the right size. Undid the four screws and tie wrap and removed the ducting (none of mine were damaged in any way, guessing they had previously been changed in the last 12 years) marked the wires and reconnected new peltier wires and everything works! I only had rear heating when selecting rear and ‘fault’ when selecting both. Rear was dated 2017 on plastic so not original. I was dubious this was at fault but replaced it with one from Ukraine in case the RR was just doing its weird science stuff but it tested ok and worked prior and symptoms were the same. Whipped out the front seat base bolts, tipped it back and removed four bolts holding a plastic cover in and that fell forward enough to access the four little screws. Snipped the old one out and replaced with the working peltier unit one from the rear and all works as it should. Only plug I removed under seat was the one for the peltier so job was done in under 2 hours all in for both.
So I ordered it on the 9th and received on the 21st. £80.62 delivered, longevity unknown at this time but can’t see why it shouldn’t as it appears identical in all respects and performs error free. These units are showing up now on AliExpress for around £20 so if someone wants to take a punt at these?
£21.61 | Car seat refrigeration sheet Peltier ventilation heating cooling and heating TED seat cushion modification refrigeration
https://a.aliexpress.com/_mNDx6oC
Post #662528 22nd Apr 2023 2:57pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
Hi All, great stuff, thank you all. I just fixed my broken duct in drivers seat with hot glue, seems to be working fine now. I measured the resistance in peltier element and matches the values to the ones from this YouTube video:
I have a small issue though :/ While I was trying to put the trim cover back on, I snapped one of the “hooks” on the back of the seat, the left blue circle. I think its fixed to the seat frame with a screw, so I assume I could replace it? Any ideas how to find the part number?
Chees 2011 Vogue SE 4.4 TDV8
Post #668829 10th Jul 2023 6:42pm
Mfcetin
Sorry here is the picture, yeah I am a newbie 2011 Vogue SE 4.4 TDV8
Post #668830 10th Jul 2023 6:44pm
Bingo_123
Is there any place for buying only the plastic ducting.
I took the seats apart, and it's the ducting that's cracked badly, peltier unit looks ok as per multimeter and cooled seats work.
So looking to buy the ducting if there is any way. Please advise.
Thanks
Post #676725 28th Oct 2023 4:42pm
Mfcetin
Ebay https://www.ebay.de/itm/114711604111?mkcid...media=COPY 2011 Vogue SE 4.4 TDV8
Post #676726 28th Oct 2023 5:24pm
Mattds2212
Post #676731 28th Oct 2023 6:30pm
Bingo_123
Thanks mate, v helpful
Post #676742 28th Oct 2023 8:39pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I have two plastic duct's for sale.
https://www.fullfatrr.com/forum/topic67666.html 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #676753 29th Oct 2023 9:30am
Bingo_123
Sorry tinman, £75 for a used ducting is way too much.
Post #676768 29th Oct 2023 12:26pm
