Home > Technical (L322) > Delayed Air Con |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
I think that will prob be different. This issue is no air con at all, then everything ok.
13th May 2024 7:00pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
Thanks for that !!
14th May 2024 7:09pm |
Nice one. Glad you got it sorted.
14th May 2024 8:22pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Glad this was resurrected As my fairly new to me 09 (2010 MY) has been doing this and it really threw me as to why as I never had that issue in my 07. I’ll try a regas to make sure that is where it should be and if not, I guess I’ll be replacing the compressor too! 2009 (2010 MY) 5.0 Supercharged Autobiography
14th May 2024 9:06pm |
So was I ! It was about 120 or I think the wifey said but she got a loaner car ("her comment: "We'll definitely not buy a Renault!" ) and (so far) we didn't have to fork out for a new compressor !! (Not to mention spending more time laying on the drive) I hope it'll solve your issue as well TDV8 Paul ! Cheers, Ard |
15th May 2024 7:14pm |
Thank you Dutchgit, my fingers are crossed when I get round to it at some point! 2009 (2010 MY) 5.0 Supercharged Autobiography
15th May 2024 8:32pm |
Make sure your aircon is turned off just in case the oil runs out of it completely.
17th May 2024 5:56pm |
miketrike Member Since: 24 Mar 2024 Location: birmingham Posts: 12 |
22nd Jun 2024 9:17am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 804 |
Interesting, from cross referencing the part no LR056364
29th Jul 2024 10:44pm |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 |
So my 2012 L322 Westminster has started doing a couple of odd things re the AC:
17th Aug 2024 2:50pm |
Sounds like the valve issue, though mine works nice and cold once it’s all got itself together…. So maybe you have 2 issues, but I think if you change the valve/compressor it will have to be re gassed anyway.
17th Aug 2024 5:00pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Sounds like the compressor to me and similar to my symptoms. Depending on your budget you may want to get a few other items replaced like the belt and tensioners, waterpump, alternator etc as a lot of the labour involves removing the fan and shroud to get at it and these other items are then also replaceable. 2012 TDV8 Vogue (L322) |
17th Aug 2024 5:06pm |
