![]() | Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I know, only 7, still will give me plenty to practice on |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
yes, thanks for that
I have been some of the way there in replacing the front out cv joints and all the suspension arms and struts. It is a place for long breaker bars. The front driveshafts pop out the front diff so not much left after that. You could try and see if you can tension the chain from just removing the lower sump plate but from memory I couldn't see anything. |
i can see the bolt but thats all RR 2005 4.4 petrol
Is it the bolt with a grub screw up the middle or something similar ? |
"Is it the bolt with a grub screw up the middle or something similar"
For some reason I am not getting the notifications in my emails when someone posts any more, strange RR 2005 4.4 petrol
Full marks for perseverance |
i would like to see an engine in bits, makes it much easier to know what you are doing, especially when you are looking for oil leaks
One of my torque wrenches, you can push the square drive through to the other side and then reverse the rather direction and it works I think from memory. I always test it on a low setting with the square drive in the vice. |
Turn vanos shaft counter clockwise until end adjustment position (vanos turning tool & 24mm
As long as the vanos is fully rotated anti clockwise then you will be ok, mine wouldn’t beep on the continuity test when I rebuilt the engine but did when I stripped it down again later. Once it was done up I turned the engine two turns and locked it up again and put all the locking tools back in place and rechecked it. Are you following the beisan procedure? |
the two upper timing chain covers are no lining up properly, i am unable to fit the seals that fit around the vanos solenoids RR 2005 4.4 petrol
