![]() | Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
Received the last of the parts I ordered to day, still got some parts to order but they are not holding me up as of now.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The top cover o rings sit around the little aluminum inserts that go into the plastic cover on each cam cover, total waste of time and an anticlimax when i found out what they are for.
right, thanks
no bother mate, i told you it would be disappointing |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 318 ![]() ![]() ![]() |
good one
I've got mine apart again...
Hi
The o rings for the tensioners come with the Beisan seals kit mate |
yes i fitted them RR 2005 4.4 petrol
Well, no progress on this of late
Mine is still knocking and I have since bought another engine to strip down but the upper sump and oil was removed.
thanks holidaychicken
I think in Rave it mentions removing the sump gasket but it leads you off to look at other sections but I think it is missing removing the diff and or driveshafts. I’ll check when I’m back. My oil pump chain was a little loose but my hands were too full to work out if I could tension it from below.
