Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
Received the last of the parts I ordered to day, still got some parts to order but they are not holding me up as of now.
25th May 2018 2:08pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
The top cover o rings sit around the little aluminum inserts that go into the plastic cover on each cam cover, total waste of time and an anticlimax when i found out what they are for.
25th May 2018 7:02pm |
right, thanks
26th May 2018 12:02am |
no bother mate, i told you it would be disappointing |
26th May 2018 7:05pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
8th Jun 2018 7:28am |
good one
8th Jun 2018 10:57am |
I've got mine apart again...
8th Jun 2018 5:59pm |
Hi
9th Jun 2018 1:47am |
The o rings for the tensioners come with the Beisan seals kit mate |
10th Jun 2018 10:39am |
yes i fitted them RR 2005 4.4 petrol
10th Jun 2018 11:14am |
Well, no progress on this of late
9th Sep 2018 1:37pm |
Mine is still knocking and I have since bought another engine to strip down but the upper sump and oil was removed.
11th Sep 2018 12:05am |
thanks holidaychicken
11th Sep 2018 12:35am |
I think in Rave it mentions removing the sump gasket but it leads you off to look at other sections but I think it is missing removing the diff and or driveshafts. I’ll check when I’m back. My oil pump chain was a little loose but my hands were too full to work out if I could tension it from below.
11th Sep 2018 6:56pm |
