Home > My Range Rover > range rover with problems
Page 10 of 18 <123 ... 91011 ... 161718>
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
@knares, did change only the four seals from the two VANOS, today closed the underbody of engine and made setting Timing chain times. Will see in some weeks when ready, is an old 540i Protection for privat use....
 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #478401 14th May 2018 7:59pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Received the last of the parts I ordered to day, still got some parts to order but they are not holding me up as of now.
When I ordered the vanos kit, it came with a number of seals
“Note: Seals kit incorporates
4 x engine top cover bolt shaft O-ring,
2 x secondary air pipe end O-ring,
2 x camshaft chain tensioner O-ring.”
So, my question is
What is the
and
secondary air pipe
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #479354 25th May 2018 2:08pm
holidaychicken
The top cover o rings sit around the little aluminum inserts that go into the plastic cover on each cam cover, total waste of time and an anticlimax when i found out what they are for.
The SAI is another wonderfully useless invention that pumps extra air into the engine for a short time at start up think for something o do with emissions somewhere, so important, i don't even have one to get in my way and if you are lucky, you won't have either.
Post #479366 25th May 2018 7:02pm
knares
right, thanks
as it is a vanos kit, i thought it would have to be something to do with the vanos
Post #479382 26th May 2018 12:02am
holidaychicken
no bother mate, i told you it would be disappointing Smile
Post #479425 26th May 2018 7:05pm
Meerbusch
Engine starts and runs smoothly, puh..., what a kind of work. Important is the correct tool kit, and the 4 "Nockenwellen" must have the upside position that you can read A E. Next time I can make this repair in half the time. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #480400 8th Jun 2018 7:28am
knares
good one
i am slow on mine RR 2005 4.4 petrol
Post #480414 8th Jun 2018 10:57am
holidaychicken
I've got mine apart again...
I have had a tapping noise on and off for a while which goes away mostly if I give it some lively driving which i think is the hydraulic lifters. It's already had all the timing chains and guides and new main tensioner but the cam chain tensioners i just replaced the seal so i am going to renew them and this time i am going to take the cams and lifters out to see what i can find.
All good fun, I am down to the cam removal stage.
Post #480457 8th Jun 2018 5:59pm
knares
Hi
If you mean the tensioners for the top chains, I did the same
I renewed the O ring in the non return valve for the vanos, which I had to buy separately.
I don’t seem to be able to find a place to buy the O ring seals it a kit.
I haven’t tried BMW as yet RR 2005 4.4 petrol
Post #480494 9th Jun 2018 1:47am
holidaychicken
The o rings for the tensioners come with the Beisan seals kit mate
Post #480578 10th Jun 2018 10:39am
knares
yes i fitted them RR 2005 4.4 petrol
Post #480582 10th Jun 2018 11:14am
knares
Well, no progress on this of late
Weather being cold and wet, although it is under cover, just, and other things to do.
I keep thinking about the oil pump chain, it would have done the same work as the other chains and it is quite slack.
I intend to go north with this and my caravan when this is going and I don’t want to be thinking about the chain when I am 2000km from home.
What’s involved in doing the oil pump chain?
I have googled it and when that question is answered, ever one goes around the answer RR 2005 4.4 petrol
Post #488496 9th Sep 2018 1:37pm
holidaychicken
Mine is still knocking and I have since bought another engine to strip down but the upper sump and oil was removed.
Check in Rave but I think the lower and upper sump has to be removed to tighten it on a RR which means front diff removal . The engine fitted in the BMW cars don’t have that so you can tighten the chain by just removing the lower sump. Download Rave and check it out as I might forget before morning
Post #488629 11th Sep 2018 12:05am
knares
thanks holidaychicken
i have looked in rave but could not find any thing
i did find a Section, replacing the oil pump, but no mention about removing the upper sump and the picture they have of the sump looks like it would be off a BMW RR 2005 4.4 petrol
Post #488630 11th Sep 2018 12:35am
holidaychicken
I think in Rave it mentions removing the sump gasket but it leads you off to look at other sections but I think it is missing removing the diff and or driveshafts. I’ll check when I’m back. My oil pump chain was a little loose but my hands were too full to work out if I could tension it from below.
I have bought an old engine to strip down and play with, it has 7 damaged bores so plenty to keep me busy.
Post #488700 11th Sep 2018 6:56pm
