Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
Hi
7th Jul 2019 12:40pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
Just pull off the black plastic bung and attach the drain tube... right next to the oil filler cap.
7th Jul 2019 12:50pm |
K6rop Member Since: 13 Nov 2018 Location: Consett Co Durham Posts: 5 |
Thanks for all the info lads , bought myself a pump and going to do it this weekend
18th Jul 2019 3:12pm |
Forgot to add my picture 😂 |
18th Jul 2019 3:14pm |
Simply prise out the outlet bung ( with the suction tube in the top ) with a screwdriver and you will see it is moulded in the shape of a spout, so just put a tundish into your empty 5 litre containers and pour it in
18th Jul 2019 3:45pm |
Wow that was so easy , bought genuine Land Rover parts and the castrol oil they recommend £213 in total
20th Jul 2019 8:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Start with 8L and then top up as indicated on sensor using the tips in this thread. I had to take mine back to garage tonight to have excess dropped as it was reading overfilled after an oil change. We dropped 2 litres then topped up as indicated on the dash. About 1L to bring to a normal level. Will be double checking cold tomorrow morning
24th Jul 2019 7:59pm |
This morning I read it cold and it said to add 0.5L. When warm it was one notch above middle line. Added 0.3L and it’s gone up one notch. Check again tomorrow.
25th Jul 2019 4:25pm |
They are a bit pricey Rob, but , compared to MD prices for an oil service , it will soon pay dividends.
25th Jul 2019 6:09pm |
Indeed Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Jul 2019 8:47pm |
Where do folks get their oil from? Advanced do 5L Ravenol for £42. There is cheaper but seems reasonable to me plus I get free delivery via their local delivery van Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jul 2019 7:40am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Dr Rob you need to use Shell Helix AF-L
26th Jul 2019 8:04am |
Rob,
26th Jul 2019 8:24am |
26th Jul 2019 9:46am |
