![]() | Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Thx Nino - so are you saying you get more oil out using this additional drain point?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Greg,
Nice one Mike!
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
As for engine oil volume, mine took 9 litres exactly after two top ups / re checks.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
so we're still not absolutely clear whether the reading is correct when hot as specified in the WM , or when cold as per Ninos suggestion.. ... - .- -.
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
Is the suction method what MDs use when servicing FFs? Obviously with the applicant engine type.
I have sucked mine out 3 times now and always got out over 9 to 9.25 litres of hot oil.
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 ![]() ![]() ![]() |
Having done many oil changes on many cars over the years, I sucked 9 litres of oil out in a few minutes and certainly won't be going back to dropping oil out of the bottom!! 2004 TD6 - Gone
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Mike
Rob,
Rob,
