![]() | Home > Maintenance & Mods (L322) > 2010-2012 key fobs |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Refurbed both my fobs just now and only took 20 mins to do both with genuine parts (LR052905) following instructions on this thread. Then just 5 mins to see why one didn't work. Yes I'd put the battery in upside down! |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
There is an affordable way.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
Andy, contact Craig at cam-tec...he should be able to help you.. ... - .- -.
Many Thanks Stan
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Could you report back if successful or not Andy? I have a similar need, dealership told me £700 for parts (as said needed a new module as well as key, as no way to programme third key for any one module). With labour guessing there won't be much change from £1k so will just be careful with the key... |
Any good auto locksmith can make you a 2nd remote key, or get yourself an GAP IID tool and a blank remote and do it at home yourself for half the price - and then you also have an IID tool. 2015 Range Rover Autobiography 4.4 SDV8 |
Sounds great thanks, i have the Gap IID, they said something about post-2011 cars' modules being locked to two key ids. Cheers for the info i will look into that 👍 |
Make sure your IID is up to date. Plug it into your car and under the service menu, you'll see the programme key function. A blank remote with transponder is about £90 on Amazon/ebay. Then you can programme it with your IID tool and just get the key blade cut at your local locksmith. 2015 Range Rover Autobiography 4.4 SDV8 |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
Gary do you want to visit Ireland most beautiful scenery which is world renowned and maybe through the ole gap tool in the bag?!
Lot more expensive, might be worth jumping on Ryanair for £30 and picking one up!
Hi RovingCanary
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
I just took the guts out of my old big key fob shaved a bit off the circuit board and put it in a new case I bought from Ali Express and it worked fine - it even says Range Rover on it. Geoff |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 ![]() ![]() ![]() |
A little thread resuscitation.
