Home > Maintenance & Mods (L322) > 2010-2012 key fobs |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
Refurbed both my fobs just now and only took 20 mins to do both with genuine parts (LR052905) following instructions on this thread. Then just 5 mins to see why one didn't work. Yes I'd put the battery in upside down!
25th Nov 2020 1:11pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 611 |
Hi,
12th Jan 2024 10:22pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
There is an affordable way.
12th Jan 2024 11:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 |
Andy, contact Craig at cam-tec...he should be able to help you.. ... - .- -.
13th Jan 2024 8:19am |
Many Thanks Stan
13th Jan 2024 3:42pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Could you report back if successful or not Andy? I have a similar need, dealership told me £700 for parts (as said needed a new module as well as key, as no way to programme third key for any one module). With labour guessing there won't be much change from £1k so will just be careful with the key... |
16th Jan 2024 3:45pm |
Any good auto locksmith can make you a 2nd remote key, or get yourself an GAP IID tool and a blank remote and do it at home yourself for half the price - and then you also have an IID tool. 2015 Range Rover Autobiography 4.4 SDV8 |
16th Jan 2024 10:18pm |
Sounds great thanks, i have the Gap IID, they said something about post-2011 cars' modules being locked to two key ids. Cheers for the info i will look into that 👍 |
16th Jan 2024 10:47pm |
Make sure your IID is up to date. Plug it into your car and under the service menu, you'll see the programme key function. A blank remote with transponder is about £90 on Amazon/ebay. Then you can programme it with your IID tool and just get the key blade cut at your local locksmith. 2015 Range Rover Autobiography 4.4 SDV8 |
16th Jan 2024 10:49pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 |
Gary do you want to visit Ireland most beautiful scenery which is world renowned and maybe through the ole gap tool in the bag?!
17th Jan 2024 9:25am |
Lot more expensive, might be worth jumping on Ryanair for £30 and picking one up!
13th Feb 2024 8:18pm |
Hi RovingCanary
14th Feb 2024 9:26am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 |
I just took the guts out of my old big key fob shaved a bit off the circuit board and put it in a new case I bought from Ali Express and it worked fine - it even says Range Rover on it. Geoff |
14th Feb 2024 9:56am |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 |
A little thread resuscitation.
30th Dec 2024 6:17am |
