![]() | Home > Maintenance & Mods (L322) > Drivers Door Handle |
joanne Member Since: 19 Nov 2010 Location: uk Posts: 427 ![]() ![]() |
Will I actually ever need to go to a garage again???? All I could do is ask you guys.....
I've just spoken to LR this morning regarding the cable. Apparently there are two cables and they cost £7.00-£8.00 each. I was told the most common one for breaking was the lock to exterior handle, but it is my interior handle that is notchy. For the sake of a few pounds and whilst the door is stripped I am going to change both cables. |
I now have the two cables at a cost of £16.30 so will fit them today |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35536 ![]() ![]() |
crikey you dont hang about....... |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Hot flushes at night can be such a bitch............ ![]() ![]() |
The two new cables are fitted, the most difficult part is removing and refitting the door card, it's a pig of a job that requires a little patience so that nothing breaks. The lock mechanism has to be removed from the vehicle to replace the cable that runs from the inner handle, if the cable from the outer handle is broken this can be replaced with the lock in situ.
good review , glad it went ok.. |
This is the two cables, the one at the top is the exterior handle to lock cable and the lower cable is the interior handle cable to lock
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Arrived today but way to cold / dark to do it now. Does any one know the card seems to be held with torx screws from the clip I saw. What size? I'm not confident that my socket set will get in to access the screws so I'll get the relevant torx type screwdriver before hand. 2010 Disco XS TDV6, 2009 Freelander 2 GS
There are two different sized Torx heads, I'll have a look later and let you know the sizes |
The two sizes you require are T20 & T30 |
Thanks dude! |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
-5C this morning and the drivers door wouldn't stay shut (once I had got in), so I locked it with the button ... Then 20 minutes later, after unlocking with the central locking, neither inside nor outside door handle would open the door - is it likely that both cables have gone ? |
It's sounds like the lock mechanism that has frozen |
