![]() | Home > Maintenance & Mods (L322) > Gearbox Service (L322 4.4v8) |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
No warning light I’m afraid, nor a dipstick. The transmission has a filler/level plug on its RH side near the back and the fluid level has to be checked manually.
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Useful info thanks.
In my experience, once you have signs of gearbox issues, it is already too late. I'd suggest, replace the lot (oil and filter) and you will probably be fine for quite some mileage |
You mean - replace the lot as per the above service |
The GM ‘box used in the TD6 has a notoriously short life span – typically 80k to 100k miles (there are exceptions of course). The ZF 5-speed transmission, on the other hand, doesn’t have nearly so bad a reputation.
Thanks for the info again - good to hear.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
the craig-meister did my SC at around 70k miles , not because it needed it but it was done as a preventive maintenance job..
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 ![]() ![]() ![]() |
I think my 4.2 S/C will have the ZF6HP26 gear box according to your chart in the WIKI and would therefore need to specific fluid you mentioned.
Would a gearbox service replacing oil and filter imply it will no longer fail? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
cheaper oil, (same stuff) here.. that price for 8 litres will save you quite a lot. -and opie oils is a site trusted on here. http://www.ebay.co.uk/itm/Mobil-ATF-LT-711...2a32ff8c0a
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Blackstoun, your sc will indeed have the 6hp26 box, and definitely needs the right fluid, zf lifeguard 6, Myele also do the same stuff apparently, but I put lifeguard in mine.
Thanks for that
there are many long threads regarding 'gearbox flush' etc |
Yes I know but it's not really conclusive and I was looking for the conventional wisdom from rrphil, or at least his view on it
