Home > Maintenance & Mods (L322) > Gearbox Service (L322 4.4v8) |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 955 |
No warning light I’m afraid, nor a dipstick. The transmission has a filler/level plug on its RH side near the back and the fluid level has to be checked manually.
18th Sep 2015 8:16pm |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
Useful info thanks.
21st Sep 2015 10:42am |
In my experience, once you have signs of gearbox issues, it is already too late. I'd suggest, replace the lot (oil and filter) and you will probably be fine for quite some mileage . MY 2010 5.0 SC Galway green and sand interior!!
21st Sep 2015 11:15am |
You mean - replace the lot as per the above service Not replace the whole gearbox?
21st Sep 2015 12:39pm |
The GM ‘box used in the TD6 has a notoriously short life span – typically 80k to 100k miles (there are exceptions of course). The ZF 5-speed transmission, on the other hand, doesn’t have nearly so bad a reputation.
21st Sep 2015 3:18pm |
Thanks for the info again - good to hear.
21st Sep 2015 3:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35176 |
the craig-meister did my SC at around 70k miles , not because it needed it but it was done as a preventive maintenance job..
21st Sep 2015 4:01pm |
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 |
I think my 4.2 S/C will have the ZF6HP26 gear box according to your chart in the WIKI and would therefore need to specific fluid you mentioned.
21st Sep 2015 4:15pm |
Would a gearbox service replacing oil and filter imply it will no longer fail? |
21st Sep 2015 6:01pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
cheaper oil, (same stuff) here.. that price for 8 litres will save you quite a lot. -and opie oils is a site trusted on here. http://www.ebay.co.uk/itm/Mobil-ATF-LT-711...2a32ff8c0a
21st Sep 2015 6:17pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Blackstoun, your sc will indeed have the 6hp26 box, and definitely needs the right fluid, zf lifeguard 6, Myele also do the same stuff apparently, but I put lifeguard in mine.
21st Sep 2015 8:21pm |
Thanks for that
22nd Sep 2015 9:11am |
there are many long threads regarding 'gearbox flush' etc |
22nd Sep 2015 9:31am |
Yes I know but it's not really conclusive and I was looking for the conventional wisdom from rrphil, or at least his view on it
22nd Sep 2015 10:15am |
