Home > Maintenance & Mods (L322) > Battery voltage, stall and other gremlins.. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Yes it should be around there BUT, i suspect thats your alternator output rather than the battery output so, does NOT tell you the condition of the battery sir... |
23rd Mar 2015 9:04am |
Jimmy_75000 Member Since: 06 Jan 2015 Location: London, UK Posts: 27 |
Thank you, will stop somewhere in the way home to try to have it check... Range Rover Vogue ‘17 TDV6
23rd Mar 2015 9:40am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
On a previous RR when I had alternator trouble, the voltage spiked and caused the transmission to shunt, the dial stopped working, lights wouldn't work, but the engine did not stall. Discovery 4 HSE
23rd Mar 2015 10:35am |
Cam,
23rd Mar 2015 11:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
you need to get the codes read cos it could be electrical or fuel related... ... - .- -.
23rd Mar 2015 11:38am |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 |
Hi,
23rd Mar 2015 12:14pm |
Thank you Range Rover Vogue ‘17 TDV6
23rd Mar 2015 4:44pm |
Well battery is perfect! Off to my local garage on Saturday to check the error messages. Range Rover Vogue ‘17 TDV6
23rd Mar 2015 7:09pm |
So we just read the errors codes and here they are:
28th Mar 2015 9:38am |
Went to my local Range Rover dealer after having the small repair shop reading the faults to me. The main dealer technician had a look at the car and said that its the dpf causing all the issue. Asked me to go for a good 1/2 hour drive on the highway to clean it up and hopefully, most issues should be fine. If not, I should book it in for inspection. Range Rover Vogue ‘17 TDV6
28th Mar 2015 12:43pm |
