Home > Maintenance & Mods (L322) > Battery voltage, stall and other gremlins..
Jimmy_75000
France 2011 Range Rover Vogue SE TDV8 Atacama Sand
Hello,
Every now and then, the car will stall when driving off (even if the car is "hot") and sometime end up in limp home which would clear after turning the engine off for 15minutes or so.
I understand from going through the forum that the battery could be a culprit and have been monitoring the voltage through the "secret" code on the gps screen... But I was wondering how reliable it is as the voltage has been hovering between 14.0 to 14.5 ....
As, can someone confirm that a standard voltage should be 14.5 when the engine is running?
Thank you! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #319163 23rd Mar 2015 9:58am
Yes it should be around there BUT, i suspect thats your alternator output rather than the battery output so, does NOT tell you the condition of the battery sir... Whistle
Post #319166 23rd Mar 2015 10:04am
Jimmy_75000
Thank you, will stop somewhere in the way home to try to have it check... Range Rover Vogue ‘17 TDV6
Post #319175 23rd Mar 2015 10:40am
On a previous RR when I had alternator trouble, the voltage spiked and caused the transmission to shunt, the dial stopped working, lights wouldn't work, but the engine did not stall. Discovery 4 HSE
Post #319188 23rd Mar 2015 11:35am
Jimmy_75000
Cam,
Do you happen to know what the correct voltage should be with the "key" in position two? (Ie engine not running) Range Rover Vogue ‘17 TDV6
Post #319190 23rd Mar 2015 12:35pm
you need to get the codes read cos it could be electrical or fuel related... ... - .- -.
Post #319191 23rd Mar 2015 12:38pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
Hi,
I have similar 4.4 TDV8 like you. Recently installed the Ctek comfort indicator on the battery, which shows the battery voltage through a flashing led. green, amber or red. In almost all cases (when parked) it flashes red, what is meaning voltage is bellow 12,4V... Although I do not have any other problems with the battery, it runs great, but a few hours after my weekly charging it returns to red again... 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #319196 23rd Mar 2015 1:14pm
Jimmy_75000
Thank you Range Rover Vogue ‘17 TDV6
Post #319245 23rd Mar 2015 5:44pm
Jimmy_75000
Well battery is perfect! Off to my local garage on Saturday to check the error messages. Range Rover Vogue ‘17 TDV6
Post #319283 23rd Mar 2015 8:09pm
Jimmy_75000
So we just read the errors codes and here they are:
Any toughs? Range Rover Vogue ‘17 TDV6
Post #320184 28th Mar 2015 10:38am
Jimmy_75000
Went to my local Range Rover dealer after having the small repair shop reading the faults to me. The main dealer technician had a look at the car and said that its the dpf causing all the issue. Asked me to go for a good 1/2 hour drive on the highway to clean it up and hopefully, most issues should be fine. If not, I should book it in for inspection. Range Rover Vogue ‘17 TDV6
Post #320207 28th Mar 2015 1:43pm
