![]() | Home > Maintenance & Mods (L322) > Battery voltage, stall and other gremlins.. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes it should be around there BUT, i suspect thats your alternator output rather than the battery output so, does NOT tell you the condition of the battery sir... |
Jimmy_75000 Member Since: 06 Jan 2015 Location: London, UK Posts: 27 ![]() ![]() ![]() |
Thank you, will stop somewhere in the way home to try to have it check... Range Rover Vogue ‘17 TDV6
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
On a previous RR when I had alternator trouble, the voltage spiked and caused the transmission to shunt, the dial stopped working, lights wouldn't work, but the engine did not stall. Discovery 4 HSE
Cam,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
you need to get the codes read cos it could be electrical or fuel related... ... - .- -.
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
Hi,
Thank you Range Rover Vogue ‘17 TDV6
Well battery is perfect! Off to my local garage on Saturday to check the error messages. Range Rover Vogue ‘17 TDV6
So we just read the errors codes and here they are:
Went to my local Range Rover dealer after having the small repair shop reading the faults to me. The main dealer technician had a look at the car and said that its the dpf causing all the issue. Asked me to go for a good 1/2 hour drive on the highway to clean it up and hopefully, most issues should be fine. If not, I should book it in for inspection. Range Rover Vogue ‘17 TDV6
