![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
yes Phil, I checked more than one time since I know that you always ask for peg position
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
P0720 (output speed sensor) is a fault code commonly flagged when the transfer box shift motor potentiometer is sending out a faulty signal. Can you select low range and get back into high again?
to be honest at first start, after box refitted, the t-case yellow light was blinking without reason.
I believe that the BMW part number for ZF Lifeguard Fluid 5 / Mobil ATF LT71141 is 83229407807. The part numbers sometimes change though depending on the quantity e.g. a 20 litre drum or a 1 litre bottle.
Thanks Phil, I asked because here in Italy we have no way to buy LT71141, less than 20 liters, and from Germany need 4 working days, than sometime I bought parts quickly from BMW dealer if compatible. But I want no risk, so I will go for Mobil.
So, I removed T-CASE because thinking , leak on output shaft seal, I know position incorrect. but not too much oil found
The plugged hole at the back is there to provide access for inserting/removing the pivot pin for the park lock pawl
at least I know what is ...but I'm very confused for trans drive mode problem and I don't know where look..and what wrong.Don't believe low level of fluid can cause a suddenly blockage...right Phil?
T-CASE shift motor tested like follow..
this morning I started to look what is wrong, so the first point to check is valve block, and I realized that the springs DA and DC are exchanged
after a complete check on to the valve block, I re-stripped the tower inside, and noticed a gascket missing. but I'm 100 % sure that was fitted..so now just can fit the old one, and try
transmission fitted for the second time, but the problem is the same.
This morning tried T-case shift motor, pressing central console button, dashboard indicate high range but yellow light blinking yet. so I had shut off engine and restart, and the light stays on. Pressing button to engage low range, and yellow blink, so again, restart engine and came ok.
just now the first test on the road and : I noticed the problem about shift fom 1st to 2st up shift only (down shift is ok) 1st 2st 3st 4st 5st and reverse are ok .
after a short holiday, yesterday the restart to try solve transmission issue between 1st to 2nd gear, since in manual mode 2/3/4/5 and reverse was ok, so checked for E brake (engaged only in 2nd but nothing wrong, and for exclusion the freewheel (engaged in 1st and 2,1st gear)than a broken freewheel cage was culprit, I believe (I hope because no more patience)
