Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
yes Phil, I checked more than one time since I know that you always ask for peg position
6th Aug 2015 10:02am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
P0720 (output speed sensor) is a fault code commonly flagged when the transfer box shift motor potentiometer is sending out a faulty signal. Can you select low range and get back into high again?
6th Aug 2015 10:36am |
to be honest at first start, after box refitted, the t-case yellow light was blinking without reason.
6th Aug 2015 11:36am |
I believe that the BMW part number for ZF Lifeguard Fluid 5 / Mobil ATF LT71141 is 83229407807. The part numbers sometimes change though depending on the quantity e.g. a 20 litre drum or a 1 litre bottle.
6th Aug 2015 1:22pm |
Thanks Phil, I asked because here in Italy we have no way to buy LT71141, less than 20 liters, and from Germany need 4 working days, than sometime I bought parts quickly from BMW dealer if compatible. But I want no risk, so I will go for Mobil.
6th Aug 2015 2:13pm |
So, I removed T-CASE because thinking , leak on output shaft seal, I know position incorrect. but not too much oil found
6th Aug 2015 11:05pm |
The plugged hole at the back is there to provide access for inserting/removing the pivot pin for the park lock pawl
7th Aug 2015 11:03am |
at least I know what is ...but I'm very confused for trans drive mode problem and I don't know where look..and what wrong.Don't believe low level of fluid can cause a suddenly blockage...right Phil?
7th Aug 2015 11:35am |
T-CASE shift motor tested like follow..
7th Aug 2015 7:15pm |
this morning I started to look what is wrong, so the first point to check is valve block, and I realized that the springs DA and DC are exchanged
8th Aug 2015 12:20pm |
after a complete check on to the valve block, I re-stripped the tower inside, and noticed a gascket missing. but I'm 100 % sure that was fitted..so now just can fit the old one, and try
8th Aug 2015 8:38pm |
transmission fitted for the second time, but the problem is the same.
11th Aug 2015 12:18pm |
This morning tried T-case shift motor, pressing central console button, dashboard indicate high range but yellow light blinking yet. so I had shut off engine and restart, and the light stays on. Pressing button to engage low range, and yellow blink, so again, restart engine and came ok.
12th Aug 2015 9:08am |
just now the first test on the road and : I noticed the problem about shift fom 1st to 2st up shift only (down shift is ok) 1st 2st 3st 4st 5st and reverse are ok .
12th Aug 2015 2:15pm |
after a short holiday, yesterday the restart to try solve transmission issue between 1st to 2nd gear, since in manual mode 2/3/4/5 and reverse was ok, so checked for E brake (engaged only in 2nd but nothing wrong, and for exclusion the freewheel (engaged in 1st and 2,1st gear)than a broken freewheel cage was culprit, I believe (I hope because no more patience)
1st Sep 2015 10:42am |
