![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Been reading this with interest and must say you have the patience of a saint and you now must be very good at getting the box in and out... lets hope these last few niggles can be sorted easily...
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102
I unscrewed the TC bolts, half turn to the converter, and screwed the four bolts.
today started car and put reverse, and the same noise as a rattle, and received immediately failsafe message.
| fulmjdun Member Since: 30 Sep 2014 Location: Bristol Posts: 5
Hello all, I belong on the list of people crazy enough to have a go at rebuilding the 5HP24 autobox, so have read this and other posts with interest and immense admiration and respect for those who have given their time and knowledge freely - but am now getting to the point of pulling hair out!
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1041
A faulty sprag OWC would certainly cause problems with 1st gear, but not 2nd.
Ah, my profile was out of date, my RR is now a 4.4 V8 Autobiography, but all other details the same!
Yes, on the 1-2 upshift the E brake/clutch is applied and it takes over from the 1st gear sprag. The A clutch remains applied throughout as it’s used in 1st, 2nd, 3rd & 4th gears. 2nd gear is the only ratio which uses the E brake/clutch.
Phil,
Your wiring harness is correct and the workshop manual description is wrong. Pins 12 & 16 are both 12v power supplies for the solenoids. The wiring should be connected like this :
By the way, just curious, but have you removed the little black tubular sleeves holding the wires together between each solenoid connector or is that how you found it? The PTC sensor really shouldn’t be left to dangle like that, it should be held in by the sleeving.
I don't think a visual inspection works for the valve body, they need testing with a pressure rig...
So the saga continues:
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Not read the whole thread but when i did mine I had RRPhil inspect the valve body, I replaced all the internals that usually wear from the service kit, bearings and seals and any suspect clutch plates and had the TC refurbished by sussex auto parts.
