Home > Maintenance & Mods (L322) > Towbar Question
Page 2 of 5 <12345>
martinf wrote:
Once it is tightened up properly nobody is likely to steal it.
Agree Thumbs Up You can torque it up pretty tight - you wouldn't get it off with a regular spanner, you need torque wrench or long extension bar.
Post #303743 8th Jan 2015 8:58pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Gibberingidiot wrote:
Don't suppose you have a pic of the part (VUB503110) Thumbs Up
I will see what I can do
Post #303825 9th Jan 2015 9:37am
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Thumbs Up thanks
Post #303946 9th Jan 2015 9:56pm
miggit
Whistle I'd get yourself some shin pads, they didn't make the tow bar removable for nothing Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #303977 9th Jan 2015 11:34pm
devonchilliman
Also a great rear end protector Whistle
Post #304009 10th Jan 2015 8:10am
martinf
[img]
This is the tow bar with the bolt and the wheel wrench I use to tighten the bolt[/img]
Post #304166 11th Jan 2015 9:05am
devonchilliman
Ahh,I see now Thumbs Up ...thanks for sharing
Post #304174 11th Jan 2015 10:11am
The hole for the bolt is also threaded for half the depth -
Which means it takes ages to take on or off as the bolt has to be turned all the way through - you can't just pop it in & tighten up - hence the comments about it being more theft proof - at the end of the day, it's just a bolt, but if it's tight, its hard to start taking off & even with the right tools it takes several minutes. It's also bloody heavy - you wouldn't want to run with it.....
Post #304223 11th Jan 2015 5:08pm
devonchilliman
Thankyou,I understand now Thumbs Up..
Post #304230 11th Jan 2015 5:50pm
devonchilliman
Towbar now fitted Thumbs Up ...looks like things are slightly different now,ie no threaded bolt,just a pin !
I requested that a bolt & nut were fitted but was told that's not advisable as it is not the approved method Rolling Eyes ...so I got them to spit weld the pin to at least make it harder to be nicked.
Also they now just fit the above as standard^^^^ Rolling Eyes ...an adapter has now been ordered
Post #304705 13th Jan 2015 10:20am
Sounds like my welding method sir Whistle Whistle Whistle
Laughing Bow down Thumbs Up
Post #304712 13th Jan 2015 10:31am
devonchilliman
Whistle it'll do the job
Post #304718 13th Jan 2015 10:40am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
13pin sockets are now fitted as the norm now, as the Caravan manufacturers have been using the 13pin plug as standard since about 2009, and even the trailer manufacturers are moving to them.
The 13pin system at least doesn't have so much of a reputation of overheating and burn out as the old style 12N/12S plugs.
Post #304793 13th Jan 2015 5:40pm
miggit
You wont regret the 13 pin set up, with an adapter it gives you the best all round options Thumbs Up Plus the 13 pin wiring, assuming that it's OEM, is the only one that will accept LED's without the need to faff about with resistors to stop all the error messages on the screen of Doom, accompanied by the Bong of death Wink Had one on my FFRR for 6 months, have towed 50 odd different trailers without any drama Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #304795 13th Jan 2015 5:43pm
miggit
Actually, the reason that they are using 13 pin plugs is, all trailers made after September 2012 have to be fitted with reversing lights, and tested by VOSA or be type approved before you can use them on the road, and this is the law Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #304797 13th Jan 2015 5:47pm
Page 2 of 5 <12345>
