Home > Maintenance & Mods (L322) > Towbar Question |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
Good plan ^^^^^^^ Geoff |
21st Jan 2015 8:33am |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
Good plan chaps but seriously though this is is !!! |
21st Jan 2015 8:58am |
Interesting .lets see what I can do |
21st Jan 2015 2:45pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I have never taken a tape measure to my hitch, but I suspect that it is below 18", which is as far as I'm aware the E U standard height that all trailers must conform to. So gotta ask WHY ????????? doesn't make sense to produce a towbar that's below the standard height that all trailers must conform to. I was very disappointed when I first went to hitch up and realised that every hole was too near the deck Normally with L/R it's the other way and the hitch is way too high. Fortunately for L/R the standard is for the trailer and not the tow vehicle, but how could they get it so wrong ? Yesterday I couldn't spell Engineer... Today I are one!
21st Jan 2015 6:19pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
Lesson learned - the hitch with the screw thread may still be available - you would almost certainly find one on eBay - could well be that the dealer had stock to sell..... As long as it's a genuine part, I can't see how it could void the warranty - however, if you weld it, it almost certainly will It's a shame you're not closer, I would happily swap as I never leave mine on the car, so the bolt is a PITA. |
21st Jan 2015 8:33pm |
If you want to go down the bolt route, find yourself a friendly engineering / black smiths place and ask them to tap the hitch that you have to take a bolt, you will have to make the hole in the receiver a bit bigger. But again if you didn't want to tackle this yourself then I'm sure that the people tapping the hitch will take pitty on you.
21st Jan 2015 10:51pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
If you are under warranty then there was a service bulletin issued in around 2005 which said that if a customer complains about the rattle then the alternative part with the bolt and threaded armature should be installed. Your dealer should be aware of this but probably isn't. |
22nd Jan 2015 8:02am |
Thanks for the replies gents |
22nd Jan 2015 8:28pm |
