Home > Maintenance & Mods (L322) > Towbar Question |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
I will see what I can do |
9th Jan 2015 9:37am |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
thanks |
9th Jan 2015 9:56pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd get yourself some shin pads, they didn't make the tow bar removable for nothing Yesterday I couldn't spell Engineer... Today I are one!
9th Jan 2015 11:34pm |
Also a great rear end protector |
10th Jan 2015 8:10am |
[img]
11th Jan 2015 9:05am |
Ahh,I see now ...thanks for sharing |
11th Jan 2015 10:11am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 |
The hole for the bolt is also threaded for half the depth -
11th Jan 2015 5:08pm |
Thankyou,I understand now .. |
11th Jan 2015 5:50pm |
Towbar now fitted ...looks like things are slightly different now,ie no threaded bolt,just a pin !
13th Jan 2015 10:20am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
Sounds like my welding method sir
13th Jan 2015 10:31am |
it'll do the job |
13th Jan 2015 10:40am |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
13pin sockets are now fitted as the norm now, as the Caravan manufacturers have been using the 13pin plug as standard since about 2009, and even the trailer manufacturers are moving to them.
13th Jan 2015 5:40pm |
You wont regret the 13 pin set up, with an adapter it gives you the best all round options Plus the 13 pin wiring, assuming that it's OEM, is the only one that will accept LED's without the need to faff about with resistors to stop all the error messages on the screen of Doom, accompanied by the Bong of death Had one on my FFRR for 6 months, have towed 50 odd different trailers without any drama Yesterday I couldn't spell Engineer... Today I are one!
13th Jan 2015 5:43pm |
Actually, the reason that they are using 13 pin plugs is, all trailers made after September 2012 have to be fitted with reversing lights, and tested by VOSA or be type approved before you can use them on the road, and this is the law Yesterday I couldn't spell Engineer... Today I are one!
13th Jan 2015 5:47pm |
