![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8444 ![]() ![]() ![]() |
Is your wiring at the front of the car or in the boot?? Pete
Jbur Member Since: 09 Oct 2015 Location: Windhoek Posts: 22 ![]() ![]() ![]() |
6 meter cabling running to the back |
In the spare wheel well at the back you will find the loom going to the boot, the reversing wire is the white/yellow wire, there are two, doesn't matter which...
Pete, where can I look for the aerial amplifier? |
Check this connection for the canbus box, is it OK and is it to the right wire as there are several a similar colour...
davethomas83 Member Since: 12 Dec 2015 Location: Gloucester Posts: 30 ![]() ![]() ![]() |
Good evening all,
Need a pic of the entire lead and close ups of the ends, both sides of the plugs, showing wires and plugs... That lead looks like they have changed it, also a picture of the wiring diagram.... Pete
Hey Pete,
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 ![]() ![]() |
Really intresting,unfortunately cannot see myself being capable of doing any of this without messing it up.
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Wish I had the balls to do this. |
An I.C.E. shop will fit this for you but I have heard of them wanting up to £700 for doing it...
PaulB1976 Member Since: 02 Mar 2016 Location: Shropshire Posts: 9 ![]() ![]() ![]() |
Hello All
It's not hard if you take your time, you can also get it all running in the boot before you start the stripdown...
I am not that fussed about speed really, all I will use is the Radio, Bluetooth, GPS and maybe phone connector !
