![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That would be about 25% more MPG Pete |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8521 ![]() ![]() ![]() |
Don't like dirty smelly oil burners..... |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Jbur, what system do you have at the mo, I recently fitted an Android unit to my TD6 with the Mid unit and factory amp. I have the system running perfectly through the factory amp and re sighted the original mid unit to allow adjustment of the trip computer and cloc
Jbur Member Since: 09 Oct 2015 Location: Windhoek Posts: 22 ![]() ![]() ![]() |
wayneg, I would be interested to know how you have done it. I will post a picture soon (from my phone) of my current unit. I am in between phones and the current one has not been configured for my PC yet.
Apologies for a double dose of the same picture (I'm new to this).
Jbur, from your pictures I presume yours is a Vogue with Sat nav screen? Mine is the HSE with the Mid unit and dsp amp so not the same. The install instructions already well documented for the Vogue set-up will be your guide 2007 TDV8 VSE
Wayneg, I am sure there is a spec naming difference between the UK and South Africa models. I am not sure what I have - even the service portfolio refers only to TD6 (all I know is that it is silver, and diesel). Trim finish is definitely not the fancy wood finish spec.
I posted some pics at the end of this long thread, if you have the unit which is now in my glovebox maybe I can help but I believe you have the top spec system so cannot help with that...http://www.fullfatrr.com/forum/topic27033.html 2007 TDV8 VSE
Thank you Wayneg. Please tell me about the performance chip, or is there a forum for it? |
Wayneg, you are correct - won't work. Please tell me about the performance chip, or is there a forum on it |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Trouble with keeping the old unit is you are still relying on the old system which is well known to be temperamental to say the least... rip the lot out and get rid, stick the new one in and away you go...
probaly no fear of drowning it in water in the desert ,so you never know pete, it might just last for ever |
