![]() | Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
Jbur Member Since: 09 Oct 2015 Location: Windhoek Posts: 22 ![]() ![]() ![]() |
Help me out Pete - FBH is what again? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8536 ![]() ![]() ![]() |
Ironhorse, that's the good bit, you don't need anything else, just the Android unit, you would be amased how good the sound from it is...
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
There are lots of threads about this, like...http://www.fullfatrr.com/forum/topic8738.html?highlight=performance+chip I picked up a cheapish one from Ebay germany. With the EGR delete and clean out of the inlet manifold the car is transformed. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
I only did a couple of trips in mine before the EGR delete, chip and clean of manifold, Also did the Vortex breather swap and fitted a pipercross ( K&N type ) air filter. The difference is chalk and cheese, a massive improvement of power and economy. I run 255 50 19`s on tarmac but if going anywhere out of town swap to 265 60 18 Dunlop AT 22`s. Most Landcrusers and prado`s run that size over here so they are readily available in the small adds if you stake one. They air down nice for sand work whilst are not to aggressive to dig holes. 2007 TDV8 VSE
Get a V8, more low end grunt than you will ever need and no waiting for the turbo to spool up....
Haylands, I cant argue with that however if you travel in real remote areas with no fuel available, having a 1000klm range is a big plus. 2007 TDV8 VSE
To give you an idea why one would need more POWER. This is a bit extreme - jumping a dune in reverse |
Pete, once again you are correct. This is not a place for a Diesel. Normal off-roading however, I prefer the diesel RR. I own a L405 v8 Autobiography, but the 22" rims limits one to paved roads. When it gets a bit older, it might replace the role of my L302 Td6, when (if it ever) dies one day. My L322 has done 280,000 km already. |
Go on then... why do you have to jump a dune in reverse... too much Fosters on board?? Pete
Whats is "Fosters"??? We have proper Reinheits Gebot German bear. A good few could have been involved.
Android unit fitted. Thank you Pete for your "manual". My wiring is different to yours, but you laid a proper foundation. Rest of the info came from the Workshop Manual.Used 2-way crossovers for front speakers (tweeters on one channel and the mid and low speaker bridged). Rear Mid and low speakers are bridged. 2 Channel amp for sub. Sounds good, but not as good as original DSP amp. Once I have tidied up the wiring, will I post a picture.
Forgot to mention:
