Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 4 of 20 <123 45 ... 181920>
Jbur
South Africa 2003 Range Rover HSE Td6 Zambezi Silver
Help me out Pete - FBH is what again?
Post #353874 23rd Oct 2015 9:04pm
Ironhorse, that's the good bit, you don't need anything else, just the Android unit, you would be amased how good the sound from it is...
Jbur it's the Fuel Burning Heater, all TD6'd over here had them as standard and it's controlled from the head unit... Pete
Post #353877 23rd Oct 2015 9:17pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Jbur wrote:
Thank you Wayneg. Please tell me about the performance chip, or is there a forum for it?
There are lots of threads about this, like...http://www.fullfatrr.com/forum/topic8738.html?highlight=performance+chip
I picked up a cheapish one from Ebay germany. With the EGR delete and clean out of the inlet manifold the car is transformed. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #353916 24th Oct 2015 2:05am
Jbur
No FBH fitted in mine. A cooling plant however - it has got an awesome AC. However, just one problem with it. It seems to do either 16 degrees, or hot. Cannot maintain mid temperatures (low 20"s).
The EGR was removed without any significant difference. A while ago, performance came down and fuel consumption up. I had an exhaust built with 70mm pipe and custom silencer. Still quite - I prefer it that way. Will post a pic.
I took it to the dunes once, but struggled with lack of power. Eventually deflated the 19" 255/55 Grabber tires to 0.4 bar to cross the higher dunes. I bought a set of BMW 18" rims (we are extremely limited with availability of LR part and our exchange rate kill the idea of importing anything) and fitted 285/60 tires, but have not tried them yet in the dunes. These tires will deflate better for better flotation. This will solve the problem to a degree, but a bit more power would be great.
The Android shipped on Tuesday and arrived in Windhoek on Thursday. However, the unit is still stuck somewhere in our customs maize. To prolong my life and not to loose my sole to the devil forever, I will not enter this maze and rather wait patiently.
Post #353917 24th Oct 2015 5:52am
wayneg
I only did a couple of trips in mine before the EGR delete, chip and clean of manifold, Also did the Vortex breather swap and fitted a pipercross ( K&N type ) air filter. The difference is chalk and cheese, a massive improvement of power and economy. I run 255 50 19`s on tarmac but if going anywhere out of town swap to 265 60 18 Dunlop AT 22`s. Most Landcrusers and prado`s run that size over here so they are readily available in the small adds if you stake one. They air down nice for sand work whilst are not to aggressive to dig holes. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #353940 24th Oct 2015 10:50am
Get a V8, more low end grunt than you will ever need and no waiting for the turbo to spool up....
Pulls my 275/65/18's with no bother at all.. Thumbs Up Thumbs Up Pete
Post #353951 24th Oct 2015 11:42am
wayneg
Haylands, I cant argue with that however if you travel in real remote areas with no fuel available, having a 1000klm range is a big plus. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #353960 24th Oct 2015 2:38pm
Jbur
To give you an idea why one would need more POWER. This is a bit extreme - jumping a dune in reverse
Post #354026 25th Oct 2015 10:07am
Jbur
Post #354027 25th Oct 2015 10:08am
Jbur
Pete, once again you are correct. This is not a place for a Diesel. Normal off-roading however, I prefer the diesel RR. I own a L405 v8 Autobiography, but the 22" rims limits one to paved roads. When it gets a bit older, it might replace the role of my L302 Td6, when (if it ever) dies one day. My L322 has done 280,000 km already.
Post #354028 25th Oct 2015 10:13am
Go on then... why do you have to jump a dune in reverse... too much Fosters on board?? Pete
Post #354039 25th Oct 2015 10:53am
Jbur
Whats is "Fosters"??? We have proper Reinheits Gebot German bear. A good few could have been involved.
The dune in reverse - because we could Very Happy
Post #354071 25th Oct 2015 1:09pm
Post #354074 25th Oct 2015 1:40pm
Jbur
Android unit fitted. Thank you Pete for your "manual". My wiring is different to yours, but you laid a proper foundation. Rest of the info came from the Workshop Manual.Used 2-way crossovers for front speakers (tweeters on one channel and the mid and low speaker bridged). Rear Mid and low speakers are bridged. 2 Channel amp for sub. Sounds good, but not as good as original DSP amp. Once I have tidied up the wiring, will I post a picture.
To do, and this is where I need some assistance:
- reverse camera: which wire from the RR can I use as signal for the reverse camera.
- FM reception: reception on old (original) unit was not great, but it seems worse now. Any suggestions
Post #355472 5th Nov 2015 4:16pm
Jbur
Forgot to mention:
- to which RR wire is the back lit illumination wire of Android unit connected;
- back light of Android unit switches to "dark mode" when lights are switched on - where can I get the "lights-on" signal on RR
Post #355473 5th Nov 2015 4:22pm
