Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 12 of 36 <123 ... 111213 ... 343536>
miggit
I've already done away with the CD changer and replaced it with a Grom BT3, the Head unit still thinks its a CD!
Anyway I can't see there being enough room to get the nav head unit in the glove box with the changer in place, maybe ironhorse can shed some light on this!
Oh and I'll do the investigations if you lend me �300 on a very long term basis Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #291837 9th Nov 2014 5:35pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
it fits
no room lost it slots in where the cd changer goes
the two wires draped around it are
white for ipod/iphone ect to the headunit
grey is a usb tho the headunit
Post #291843 9th Nov 2014 5:47pm
miggit
Right, so can you still get the CD channel on the old head unit? If so my cunning plan will work using the cd wiring! Yesterday I couldn't spell Engineer... Today I are one!
Post #291844 9th Nov 2014 5:52pm
mjdronfield
On page 6 of this thread, magu posted this and asked if it would work.....
http://www.gromaudio.com/docs/bmw_dsp_kit_manual.pdf
I said I didn't think it would as the CD player still needed to be on the ibus, but if you have removed it and you can still select it with your grom fitted, would the lead allow an interface to the existing system after all ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #291849 9th Nov 2014 6:01pm
miggit
That is a digital to analogue converter for use with Logic 7 systems. You still need the base unit like the BT3 that I fitted
http://www.gromaudio.com/store/bt3_adapter...ector.html
Sorry for the delay, that link crashed my IE9 so I've had to log back in with chrome... just noticed that the emoticons are a lot better on here! And how do you stop your car spinning around like that, it's making me dizzy Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #291852 9th Nov 2014 6:16pm
mjdronfield
Ah, ok. Didn't want to have given out dud info......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #291853 9th Nov 2014 6:23pm
miggit
No probs Bud Wink
I'm just hoping that ironhorse has good news for us! It would make a far easier install Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #291854 9th Nov 2014 6:25pm
ironhorse
/normal_2013-01-08%2012%2001%2032~0.jpg[/img]
dont know what news your waiting for
its a piece of cake to do as long as you dont rush
it will take a full and long weekend to do it
it has been in my car and working for almost 5 years now well worth a bit of effort to gain a touch screen with proper satnav,
32G of albums on an SD card
6 cd storage in hard drive
DVD player
bluetooth to phone for calls or music
reverse cam
DVT
extra audio/video inputs
ipod/iphone connectivity
and loads more stuff on it that im not the slightest bit interested in
its a no brainer just do it
you wont be disappointed when you dont have to look at or operate that piece of junk they call an info center
if you do it my way it can all be put back to standard if you dont like it
simples
Post #291865 9th Nov 2014 8:10pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Which was ??? Embarassed Embarassed
Post #291892 9th Nov 2014 9:34pm
Baris
Good stuff guys. Never thought a screen would fit in the glove box lol.
As mentioned, you cannot use the cd changer as an audio input, as the bm54 won't recognise it, unless there is one connected. The auxiliary input is the best method. It is stereo sound and clear.
All you would need to do, is connect the 2 front channels from your new headunit to the auxiliary input. Leaving it on aux mode all the time, and it should work well. This is the non complicated way.
If you wanted to connect the head unit sound output direct to the dsp, there may be a few complications. When the bm54 goes into dsp mode, it stays on one volume level, which cannot be adjusted and sound only comes out of the front channels.
So volume is adjusted from the dsp. Which means, you may need to leave the new headunit on a certain volume level. This is a grey area, as no one has ever tried feeding a dsp a different sound source.
So auxiliary is the best option.
The BMW lot have bought and sold these Chinese head units, for quite a few years now. Some audio shops have stopped supplying them, due to them getting too many faulty ones. They are improving them more and more. It was a good upgrade for people who didn't have the factory sat nav system, but most who had the factory sat nav, went back to the factory, as they couldn't stand the delay and boot up time, and the touch screen was old technology. Not sure if they have improved on that. I know the processor has been increased over and over again.
Range rovers were given all the old left overs parts by BMW, so its a choice between a mk4 nav unit, or one of these units. barisahan@gmail.com
Post #292516 12th Nov 2014 5:43pm
mjdronfield
Many thanks Baris.
Was interested to get your take on it.
So no good feeding direct to DSP and cutting BM54 out the loop........
So what about feeding the aux out from the android unit to the BM54 connector in place of say the TV source and fooling the system that way ?
BM54 would feed DSP as normal and all controls work, just like when the TV is feedimng the signal.
A bit of rewiring needed with this method of course.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #292533 12th Nov 2014 6:43pm
Benjamin
United Kingdom 2003 Range Rover HSE Td6 Santorini Black
You don't want to use the TV input, for the following reasons.
-You don't have a left and right channel
-You would need to select TV option Everytime you get in your car. Where as aux would stay.
Seems like a good idea if it works.
Post #292535 12th Nov 2014 7:00pm
TV audio only mono ? .
Post #292536 12th Nov 2014 7:02pm
Baris
Agreed. Purely for the fact that the tv doesn't come back on when you re start your car. So the thought of having to lean over to select tv option from the glove box,every time you get in the car, is an unnecessary chore.
Why do you prefer to use the tv input rather than the aux input? Did you want to keep it as a separate input? barisahan@gmail.com
Post #292539 12th Nov 2014 7:09pm
mjdronfield
I was just thinking of those people without the AUX in mod on their BM54, ie without the female RCA phono plugs or the 3.5mm jack plug like you fitted to mine.
With a bit of a rewire, they could fool the system and get whats required.
Agreed, the easiest way would be to have the AUX in connectors added to the BM54.
I understood you could not use the "factory" AUX source input (already in the BM54 plug) without the latest firmware on the BM54. Is this incorrect ? And then it had to actually detect something connected to it before it was available as a source ?
Leaving my system as is...... very happy with it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #292559 12th Nov 2014 8:26pm
