![]() | Home > In Car Electronics (L322) > MK4 Sat Nav Disk |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
My sat nav was updated before I got it and has a mk 4 unit, which I was lead to believe had post codes look up in it - which mine doesn't!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
You can only enter a 5 digit postcode where you enter the "city". It says city/pc on the screen or similar. When you have put in the 5 digits, you can pick a road that the unit finds are in that area.
Mine only says "City"...
No extras... Tym
No post codes then I'm afraid. |
Do you need to have the latest firmware installed ?
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
The drawbacks of having 10 year old satnav. It really is total pants. You should see the MK III though. |
Acquired an updated disk...
How does one acquire the update? ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Interesting post, I have just spent 220 pounds on a dvd sat nav unit and supposed to be 2016 maps. I cannot find a post code search , so I assumed It was a waste of money . Then I read this thread , halaulah, there seems to be a way . I am now going to check further and need to delete a whole lot of destinations , how do I do this , I tried following the cd manual , but its not the same , seems the previous owner lived around London! Not likely to need all these , so need to delete.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
It's best to have a look on the BMW forums and search for sat nav. That's where I learned to use mine..... |
Thanks , meantime I'll have a look.
