Home > In Car Electronics (L322) > MK4 Sat Nav Disk
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
MK4 Sat Nav Disk
My sat nav was updated before I got it and has a mk 4 unit, which I was lead to believe had post codes look up in it - which mine doesn't!
Also, the map is somewhat out of date. Can it be updated, if so, to what and from where do I get it? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #263740 6th Jun 2014 10:48pm
mjdronfield
You can only enter a 5 digit postcode where you enter the "city". It says city/pc on the screen or similar. When you have put in the 5 digits, you can pick a road that the unit finds are in that area.
You will only be able to enter a 7 digit postcode if you have non standard modded firmware installed.
The map disks are Navteq ones, though you'll have to do some research as to the exact right one. They are available on the net.
General info here ;
http://bmwnavigation.co.uk/tag/bmw-sat-nav...de-how-to/
http://forum.bmw5.co.uk/topic/49838-satnav...ra-alerts/
http://www.the75andztclub.co.uk/forum/showthread.php?t=31183 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #263766 7th Jun 2014 5:50am
tymh
Mine only says "City"...
...and doesn't like any form of post code. After putting the first two letters in, the numbers stay "dull" so it seems quite obvious that mine is not set up for post codes... Censored Tym
Post #264188 9th Jun 2014 3:19pm
Might be loaded in "Extras".
Try this,
7 Digit Postcode Search
Go to the menu screen select GPS, scroll down
Select information,
Then travel information,
Then information on location,
Then extras
Then UK postcodes,
Then postcode A,B,C etc whatever postcode you need to look for.
Information
v
Travel Info
v
Info on location
v
Extras
v
UK Postcodes
Post #264192 9th Jun 2014 4:03pm
tymh
No extras... Tym
Post #264194 9th Jun 2014 4:15pm
No post codes then I'm afraid. Sad
Post #264196 9th Jun 2014 4:23pm
mjdronfield
Do you need to have the latest firmware installed ?
The latest bmw released was v32, but there is not a like for like display on the unit, ie it does not say v32 even when it's installed.
Go to the set screen and look what it lists as software.
Is it something like 1/00 from memory ?
Just had a quick google, the latest v32 is shown as 4-1/100 in the set screen..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #264216 9th Jun 2014 5:28pm
The drawbacks of having 10 year old satnav. It really is total pants. You should see the MK III though.
Post #264233 9th Jun 2014 6:38pm
tymh
Acquired an updated disk...
http://www.fullfatrr.com/forum/topic27770.html Tym
Post #284009 1st Oct 2014 9:31pm
tymh
How does one acquire the update? Twisted Evil Tym
Post #284539 5th Oct 2014 9:32pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Interesting post, I have just spent 220 pounds on a dvd sat nav unit and supposed to be 2016 maps. I cannot find a post code search , so I assumed It was a waste of money . Then I read this thread , halaulah, there seems to be a way . I am now going to check further and need to delete a whole lot of destinations , how do I do this , I tried following the cd manual , but its not the same , seems the previous owner lived around London! Not likely to need all these , so need to delete.
Has any one got an old manual for dvd machine instructions please.
Post #440454 2nd Jun 2017 6:02pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It's best to have a look on the BMW forums and search for sat nav. That's where I learned to use mine..... Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #440463 2nd Jun 2017 6:21pm
alfapat
Thanks , meantime I'll have a look.
I get the feeling that apart from postcode info, there is not a lot of improvement after spending �220,
Ok its up-to-date I think, but that could have the same effect if I ugrade the cd info.
Any thoughts
Since looked at post code facility, a bit weird for 2016 , however it seems to work, need a book.I think.
Downloaded part of the booklet from Bimmernav , everything will become clearer no I think....haha!
Post #440487 2nd Jun 2017 10:19pm
