![]() | Home > In Car Electronics (L322) > MK4 Sat Nav Disk |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
My sat nav was updated before I got it and has a mk 4 unit, which I was lead to believe had post codes look up in it - which mine doesn't!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
You can only enter a 5 digit postcode where you enter the "city". It says city/pc on the screen or similar. When you have put in the 5 digits, you can pick a road that the unit finds are in that area.
You will only be able to enter a 7 digit postcode if you have non standard modded firmware installed. The map disks are Navteq ones, though you'll have to do some research as to the exact right one. They are available on the net. General info here ; http://bmwnavigation.co.uk/tag/bmw-sat-nav...de-how-to/ http://forum.bmw5.co.uk/topic/49838-satnav...ra-alerts/ http://www.the75andztclub.co.uk/forum/showthread.php?t=31183 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Mine only says "City"...
No extras... Tym
No post codes then I'm afraid. |
Do you need to have the latest firmware installed ?
The drawbacks of having 10 year old satnav. It really is total pants. You should see the MK III though. |
Acquired an updated disk...
How does one acquire the update? ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Interesting post, I have just spent 220 pounds on a dvd sat nav unit and supposed to be 2016 maps. I cannot find a post code search , so I assumed It was a waste of money . Then I read this thread , halaulah, there seems to be a way . I am now going to check further and need to delete a whole lot of destinations , how do I do this , I tried following the cd manual , but its not the same , seems the previous owner lived around London! Not likely to need all these , so need to delete.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
It's best to have a look on the BMW forums and search for sat nav. That's where I learned to use mine..... |
Thanks , meantime I'll have a look.
