Home > In Car Electronics (L322) > MK4 Sat Nav Disk |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 311 |
My sat nav was updated before I got it and has a mk 4 unit, which I was lead to believe had post codes look up in it - which mine doesn't!
6th Jun 2014 9:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
You can only enter a 5 digit postcode where you enter the "city". It says city/pc on the screen or similar. When you have put in the 5 digits, you can pick a road that the unit finds are in that area.
7th Jun 2014 4:50am |
Mine only says "City"...
9th Jun 2014 2:19pm |
No extras... Tym
9th Jun 2014 3:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
No post codes then I'm afraid. |
9th Jun 2014 3:23pm |
Do you need to have the latest firmware installed ?
9th Jun 2014 4:28pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
The drawbacks of having 10 year old satnav. It really is total pants. You should see the MK III though. |
9th Jun 2014 5:38pm |
Acquired an updated disk...
1st Oct 2014 8:31pm |
How does one acquire the update? Tym (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
5th Oct 2014 8:32pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Interesting post, I have just spent 220 pounds on a dvd sat nav unit and supposed to be 2016 maps. I cannot find a post code search , so I assumed It was a waste of money . Then I read this thread , halaulah, there seems to be a way . I am now going to check further and need to delete a whole lot of destinations , how do I do this , I tried following the cd manual , but its not the same , seems the previous owner lived around London! Not likely to need all these , so need to delete.
2nd Jun 2017 5:02pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
It's best to have a look on the BMW forums and search for sat nav. That's where I learned to use mine..... ______________________________
2nd Jun 2017 5:21pm |
Thanks , meantime I'll have a look.
2nd Jun 2017 9:19pm |
