Home > Technical (L322) > TDV8 Complete Engine Failure
Page 2 of 6 <123456>
Vogue
Was this vehicle remapped? As I have knowledge of several TDV6 & TDV8's blowing turbos and the engine sucking the bits up ending in catastrophic failure. And also warped exhaust manifolds.
Post #225215 25th Nov 2013 9:01pm
MikeC295
2006 Range Rover Vogue TDV8 Java Black
No it wasn't remapped it was just standard. Hoping it hasn't warped the exhaust manifolds as well :/ Did the engines still run at all do you know after their turbos went?
Post #225216 25th Nov 2013 9:04pm
Vogue
No, none of the engines ran, the sumps were full of the engines internals and bits of turbo fins totally goosed
Post #225218 25th Nov 2013 9:07pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Do let us no what the diagnosis is & hope it is not as bad as you fear. If it is bad I am sure plenty of people on here can help advise you on the most sensible economic way forward is to get your FF back up & running again.
Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #225256 26th Nov 2013 12:14am
DMRR
Just a thought ... if it won't run unless the filler cap is off this would indicate an inability to vent the exhaust gasses would it not? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #225286 26th Nov 2013 9:15am
Marx Dreyer
South Africa 2008 Range Rover Vogue TDV8 Stornoway Grey
I have a 2008 model TDV8. My car lost power and a message showed on the dashboard,,''engine system fault''
I stopped, had it recovered and now Land Rover tells me the damage is R280 000. ($28000). Just like that.
Turbo failed and sucked all the oil out of the engine. The heat gauge did not even rize and the car still idled when I stopped. White smoke came out the exhaust.
They don't fix engines, they only replace it.
Does anybody know where I can find a secondhand engine as I am forced to fix the car myself?
Post #225314 26th Nov 2013 11:26am
MikeC295
Possibly? Would the indicate blown turbo or blown head gasket?
Post #225325 26th Nov 2013 12:14pm
DMRR
First quick google :
Quote:
Oily grey smoke coming out of the open oil filler cap and crankcase breather hose in significant amounts with the engine warm and running, possibly with a smell of diesel fuel. Shows that combustion pressure is passing down the bores into the crankcase. Likely causes could be broken or worn rings, badly worn pistons, and possibly worn or deeply scored cylinder(s)
 Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #225335 26th Nov 2013 1:26pm
DMRR
...which would lead to wonder about the PCV hoses possibly. However this is just a shot in the dark! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #225337 26th Nov 2013 1:27pm
MikeC295
Another thing to mention is the top right hand large hose going into the engine was completely soft and felt as though it was 'pulsing' when you squeezed it while the engine was idling...
Post #225341 26th Nov 2013 2:03pm
Marx Dreyer
I found out that when a turbo fails, it sucks the oil into the intercooler and then the oil ends up on the pistons via the air intake. This causes the conrods to bend etc etc.
Post #225354 26th Nov 2013 3:13pm
duckworthparts
Site Sponsor
i can get hold of a recon engine for you and ship it out You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #225359 26th Nov 2013 3:53pm
MikeC295
Hi duckworthparts - How much would I be looking at for a recon engine?
Post #225362 26th Nov 2013 4:29pm
Marx Dreyer
Dear Duckworth. Do you have spares as well? (conrods, bearings, pistons etc.)
What will a sub assembly or 2nd hand engine cost me?
Post #225365 26th Nov 2013 4:50pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
@Marx,
have you discussed your car's issues with some of the indies in South Africa - maybe there could be another way of solving your problem.
I think in PE there is a shop called Savoy Motors - according to the guys on the 4x4community forum he is quite good. Also have a chat with Walter @ LRZone (he is in Pretoria, but always willing to give advice).
I hope its not as serious as dealer told you as I am also considering buying a TDV8, but your experience is now scaring me off. Maybe I should just hang onto my 2004 FFRR 4.4 v8.
Again hope you come right.
Trevor
Post #225461 27th Nov 2013 4:15am
