![]() | Home > Technical (L322) > TDV8 Complete Engine Failure |
MikeC295 Member Since: 24 May 2013 Location: Durham, UK Posts: 32 ![]() ![]() |
No it wasn't remapped it was just standard. Hoping it hasn't warped the exhaust manifolds as well :/ Did the engines still run at all do you know after their turbos went? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3758 ![]() ![]() |
No, none of the engines ran, the sumps were full of the engines internals and bits of turbo fins totally goosed |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
Do let us no what the diagnosis is & hope it is not as bad as you fear. If it is bad I am sure plenty of people on here can help advise you on the most sensible economic way forward is to get your FF back up & running again.
Just a thought ... if it won't run unless the filler cap is off this would indicate an inability to vent the exhaust gasses would it not? Land Rover Addict
Marx Dreyer Member Since: 26 Nov 2013 Location: Port Elizabeth Posts: 4 ![]() ![]() ![]() |
I have a 2008 model TDV8. My car lost power and a message showed on the dashboard,,''engine system fault''
Possibly? Would the indicate blown turbo or blown head gasket? |
First quick google :
Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
...which would lead to wonder about the PCV hoses possibly. However this is just a shot in the dark! Land Rover Addict
Another thing to mention is the top right hand large hose going into the engine was completely soft and felt as though it was 'pulsing' when you squeezed it while the engine was idling... |
I found out that when a turbo fails, it sucks the oil into the intercooler and then the oil ends up on the pistons via the air intake. This causes the conrods to bend etc etc. |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
i can get hold of a recon engine for you and ship it out You can paypal direct using - www.paypal.me/duckworthparts
Hi duckworthparts - How much would I be looking at for a recon engine? |
Dear Duckworth. Do you have spares as well? (conrods, bearings, pistons etc.)
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
@Marx,
