Home > Technical (L322) > Engine System Fault
supershuttle
Engine System Fault
"Engine System Fault" warning appears every now and then just after starting car - runs fine so I just ignore it. Is that wise? Question Geoff
Post #223201 15th Nov 2013 5:52pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Got any diagnostics to pull the fault codes? .... Also maybe low battery related - try checking your voltage.
Post #223206 15th Nov 2013 6:07pm
supershuttle
Yep got IIDTool but it doesn't seem to record fault, battery is newish. Geoff
Post #223208 15th Nov 2013 6:24pm
adigorn
If that is turbo actuator sticking up than sh ould be no casualties
but if it is egr on the way out than it may finally ground you out Whistle
big time
Post #223231 15th Nov 2013 8:50pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I couldn't have put it better myself.
Post #223661 18th Nov 2013 2:28pm
kiter
I've had this as well on and off in the last few weeks, daft question but how do I know if it is the EGR thats about to go?
Thanks
Post #223686 18th Nov 2013 4:49pm
adigorn
simply by doing computer diagnostics
Post #223790 18th Nov 2013 11:19pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
I have the same issue. now and again I get the " engine system fault" warning. If I turn the engine off and restart it is OK until the next day. Does anyone know what this could be? Terry.
Post #263258 4th Jun 2014 7:24pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Could be the charge air pipes ruptured
Post #263311 4th Jun 2014 10:44pm
ebajema
I would check the EGR, clean it as they have a tendency to gunk up over time and cause issues.
I'd say once or twice a year (or just blank it), clean it so you don't have any risk of issues.
It seems something that is not working right at cold start-up, something sticking and the EGR is a good candidate for that. MY 2010 5.0 SC Galway green and sand interior!!
Post #263327 5th Jun 2014 1:05am
1959terry
Are they easy to clean?
Post #263675 6th Jun 2014 3:10pm
ebajema
There are some posts on EGR cleaning on here. I haven't done it since I have had petrols only Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #263846 7th Jun 2014 2:19pm
1959terry
I got it connected to an obd2 scanner and the following was highlighted. Code P132E turbo/supercharger boost control B performance intermittent. Looks like it could be the turbo actuator sticking.
Post #264772 11th Jun 2014 10:50pm
1959terry
Does anyone know if the turbo actuators can be changed without taking the engine out? Or maybe even lubricate the actuators at the roadside?
Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #402342 28th Aug 2016 6:44pm
fisha
It may be worth buying a short term access to topix to get at the workshop manual and the full code lists.
On my freelander I had an error which generic obd code lists suggested was egr valve error. The full error code (7digits) when listed in topix actually referred to the main throttle body as being the logged fault. Which is notably different from the generic suggestion.
The throttle, air flow, turbo and egr are all so closely linked that you really need the full error info. V8 or else ...
Post #402501 30th Aug 2016 4:33am
